Old 10-11-2024, 04:52 PM   #1
EagleChief
EagleChief's Avatar
Insane fuel tank thought!!
So, a little background on why this thought came to me - I'm adding a fuel tank under the bed for my LS swap. I still have the stock tank behind the seat. The plan is to remove it. But, my project is going on year 4-ish.
Here's my thought/question/discussion while laying in bed awake in the middle of the night, or when I wake up in the middle of the night and can't go back to sleep:
I wonder if I can leave the original tank behind the seat and re-plumb it to feed into the tank under the bed. Would it be possible to have the stock fuel tank as an extra supply on top of my fuel tank that is going under the bed? I know it would need a valve of some sort to restrict the flow into the lower tank. Gravity feed wouldn't have a way to shut off, as the tank is higher and would continuously feed the lower tank. Could I run a pump from the original to feed the other and then the main pump to go from there to the engine?
I know it's a dumb idea, but like I said. Sometimes I can't sleep and this is something that I pondered while laying in bed one night.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 10-11-2024, 05:57 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Insane fuel tank thought!!
Just use a switch to go from one to the other . I used one in my 68 for the keg gas tank I have 13 more gallons now
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-11-2024, 06:07 PM   #3
jaros44sr
jaros44sr's Avatar
These trucks did come with brass vavle for extra tanks, you could mount the vavle in the stock location
20191005_074950 by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-11-2024, 06:26 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
You would have to have a pump for sure, because the lines don’t gravity feed on the stock sending unit/tank setup. I don’t think it’s a dumb idea. I’ve thought about doing similar for my factory auxiliary tank setup so you don’t have to mess with the brass valve when the first tank runs out. As you see it running low you hit the pump in the cab tank and have it fill the under bed tank. The sending unit switch from a factory aux tank truck would be perfect to be able to see what both tanks have in them.
Tyler
57taskforce is offline   Reply With Quote
Old 10-12-2024, 02:11 AM   #5
kwmech
Did something similar with my flatbed. I have an auxiliary fuel tank under the bed behind the cab. Goes from cross member to cross member and only about 9 inches deep. Holds about 45-50 gallons. I used the newer style switching valve so I can switch the senders also
Old 10-12-2024, 11:48 AM   #6
weq92f
weq92f's Avatar
My DD has a 30 gallon tank in the bed (disguised as a tool box that sits below the bed cover level).
It has a sending unit and pump in the AUX tank and is plumbed into the factory fuel tank via the filler neck. Inside the cab I've got a toggle switch for the AUX pump and a fuel gauge for the AUX tank. Main tank gets low, just hit the switch and put more fuel in there...right?
This works as you would expect however there are some issues:
The pump runs until it is toggled back off again. If the AUX tank goes empty, pump keeps running. If the target tank becomes full and the AUX tank still has fuel, the pump keeps running eventually dumping fuel to the atmosphere via the vent and stalling the engine (due to some fuel vapor catch that gets fouled by raw fuel when this happens). Once stalled, it takes a bit to get the engine running again.
Not perfect but is workable. I've determined that running the pump for 10 minutes equates to close to 8 gallons and am considering a timer to guard against wasting fuel. When I use the thing currently, I manually time the event with my pocket computer and run it only 10 mins at a time.
YMMV,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-12-2024, 01:28 PM   #7
PbFut
Lots of things to consider here. First you are feeding a LS. Are you going carburation or fuel injected? Are you running return lines? Do you want intank pumps or inline pump. Are there sender units for gauge in each tank? The easiest way to plumb is with one inline pump and a selector valve. If you run a return line, it only adds the complication of switching its flow in sync with the feed flow. This is my device of choice. One valve for 2 tanks and it switches feed, return and sender signals. Works great. I have 3 tanks, so I need 2 valves. First valve selects main tank second valve. The second valve selects the 2 aux tanks. With the use of a 3 position rotary switch, it will switch the feed and return fuel lines and the sender signal so all circuits are sync’d at all times. No manual switching of a line valve and no out of sync toggle switch for the fuel gauge. This kit get you the pigtail. The valve does not require momentary switch. The switch can remain closed and not hurt the valve.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
PbFut is offline   Reply With Quote
Old 10-14-2024, 03:48 PM   #8
EagleChief
EagleChief's Avatar
Well, it's good to know that I wasn't going crazy!
I already have an external fuel pump that was installed by the previous owner. Actually had 2 of them for some unknown reason (never did figure that one out). I could use the one under the truck (mounted to the frame) to pull fuel from the stock tank, and send it to the rear tank. Sounds like the best solution would be to hook up an on/off switch for that pump. Run it for 'x' amount of time to dump fuel into my new tank, and just remember to shut it off.
This would allow me to keep the original fuel filler and not have to cut a new filler in the bed somewhere for the new tank. Not sure how big of a deal that is, but without having a lot of fab experience, it's one less thing to worry about.
Old 10-14-2024, 04:57 PM   #9
EagleChief
EagleChief's Avatar
It is an FI setup. The tank under the bed is set up for FI with a sump and an in-tank fuel pump.
My original tank has an added fuel pump, in-line, under the cab. I could probably use it to fill the new tank, right? By using a switch to turn it on/off?
Old 10-14-2024, 05:22 PM   #10
57taskforce
All about them K’s
Yes that would work.
Tyler
Old 10-14-2024, 07:26 PM   #11
PbFut
Running a line from one tank to the other is asking for problems with over filling the receiving tank. Normally you use one inline pump downstream from the valve. Pressure regulate the pumped fuel with return back to valve so it syncs into correct tank. Feed your fi system from the regulator.
