10-14-2024, 09:30 AM | #1 |
Soft Brake Pedal
Current project is using a 1979 K10 frame and suspension. Utilizing brake system from same, everything is new except hard lines. Drums , Rotors, proportioning valve , brake booster , Master Cylinder also were replaced. I can get a firm pedal but after cranking engine pedal fades to the floor? The brakes will hold the truck when in gear. Also will stop truck . Can’t get a good pedal with it running? Ordered another MC just to eliminate that as maybe the problem. I’m scratching my head on this one , looking for some suggestions and input. If it matters it is an 6.0 LS engine,thanks
10-14-2024, 10:30 PM | #2 |
Re: Soft Brake Pedal
Did you drill a new hole for the power brake pedal ratio?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-15-2024, 03:40 PM | #3 |
Are you getting enough vacuum? I had a lot of problems with brakes due to having too large of a cam which decreases vacuum.
10-15-2024, 03:43 PM | #4 |
10-15-2024, 10:26 PM | #5 |
Someone who has done that conversion will have to chime in on that question. I kept my truck non-power, even with the front disc swap. My initial question was partly to help the conversation begin since that's a common question anyways
10-15-2024, 10:32 PM | #6 |
^^^ I did that too. They work just fine unboosted. Sure, you have to push harder but no more so than the factory brakes required.
10-16-2024, 08:46 AM | #7 |
Thanks for the input, I’m chasing my tail on this one ! I did the math equation on pedal ratio and it came out to what it’s supposed to be for power assist brakes. I’m going to recheck it again and make sure I did it correctly
10-16-2024, 05:30 PM | #8 |
THANKS EVERYONE!!! Y’all steered me right to the problem . I had the ratios for the brake pedal backwards .I was thinking 6:1 for power assist and 4:1 for manual ???? Drilled a hole in the correct location and now I have a BRAKES and a firm pedal !!
10-21-2024, 02:27 PM | #9 |
Glad you got it fixed - drilling the lower hole is a must.
10-21-2024, 04:06 PM | #10 |
Not always!
If you have a bellcrank between your firewall and booster you use the existing hole. https://www.speedwaymotors.com/Power...iABEgJdvvD_BwE |
