Old 10-15-2024, 09:02 PM   #1
epfatboy
K10 Front Driveshaft extension/compression play
How much extension/compression play should my front drive shaft have?
Currently the truck is on the lift and I have the front end pulled apart.
At full extension (truck on lift) the front drive shaft has 1" of travel before it bottoms out in the slip yoke.
The truck is a '86 K10 with a 3 inch lift. It does not squat much when off the lift but I wasn't sure if 1" was enough travel for a front shaft.
epfatboy is offline   Reply With Quote
Old 10-18-2024, 05:55 PM   #2
cadillac_al
Re: K10 Front Driveshaft extension/compression play
I don't recall ever measuring one but it isn't much. Your 1" is probably normal.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
