Old 10-16-2024, 02:25 PM   #1
cgster
Rear bumper Question
I might upgrade my current rear bumper on my 67 C10 to the sport style rear bumper. Are the brackets the same for both rear bumpers or will I need to get new brackets as well? Thanks.
cgster is offline   Reply With Quote
Old 10-16-2024, 03:38 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Rear bumper Question
Sport bumper brackets look like this:
https://gmcpauls.com/bumpers1.htm
pjmoreland is offline   Reply With Quote
Old 10-16-2024, 04:02 PM   #3
1970cstblazer
1970cstblazer's Avatar
Arrow Re: Rear bumper Question
In addition, there are different brackets for coil spring versus leaf spring trucks.
Old 10-16-2024, 08:31 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
My Step Bumper, [SAF-T-BUMPER] is supported by a pair of rails that slide inside the rear frame rails. The angular side braces are not used.
'68OrangeSunshine is online now   Reply With Quote
Old 10-16-2024, 11:40 PM   #5
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Sort of. Op needs to measure the frame rails bolt pattern. If 7.1" it takes the longer inner brackets. If 5" the shorter ones, and both take same outer brackets. If 5.3 then likely need to make something. I'd b interested to know if its not 7.1 or 5.0. If 5.3 I can help.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
