Old 10-19-2024, 11:45 AM   #1
kglowacky
exhaust X Pipe
Been wondering how important an X-pipe set up is on a LS swap. I have a LS1 swap out of a 02 Trans am and am running dual exhaust with no x pipe. Seems to run fine. What are the advantages or disadvantages of installing an X-pipe or is there any.
kglowacky is offline   Reply With Quote
Old 10-19-2024, 04:26 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: exhaust X Pipe
I wouldn't use the word important, its about sound and fitment. the X pipe sounds different than H pipe and the true dual with no connection between each bank has a different sound aswell. Best bet youtube sound clips, but X pipes sounds more cleaner to me, H pipe has more popping tones to it, true dual pass..
if you are have the capability of welding it in yourself, buy both options and try it out.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-19-2024, 05:10 PM   #3
kglowacky
Re: exhaust X Pipe
not really going after any sound. I like the way it sounds right now. I was just wondering if these higher hp motors need the x pipe to balance the pressures. I want to make sure I am not damaging my motor long term.
Old 10-20-2024, 07:37 AM   #4
WorldsCrappiestTruck
Active Member
Re: exhaust X Pipe
Not damaging anything. Send it.
I ran true dual on my swap because I knew getting the x or H to fit with my 4L60E (when I knew I’d be going to a T56) was going to be temporary. I also added 8” long Flowmaster cats right off the header to help with exhaust fumes.
Maybe someday I’ll try an x or H but for the time being, no.
WorldsCrappiestTruck is offline   Reply With Quote
Old 10-20-2024, 09:37 AM   #5
Joyridin
Re: exhaust X Pipe
The H pipe always made sense to me, but the X pipe doesn't in some applications. I was a 3" dual exhaust on a truck with an X pipe where the center of the X was roughly 3". If you are going to take 2 3" pipes and narrow them down to 1 3" pipe, why even bother going back to the dual 3" pipes after that point?
Joyridin is offline   Reply With Quote
Old 10-21-2024, 02:09 AM   #6
Richard
Re: exhaust X Pipe
I tend to think of an x pipe kind of like the venturi's in a carb. The throat in the carb necks down to speed up the air. If it goes back to a single pipe diameter "true X" personally I would not use.
Richard
Old 10-21-2024, 11:05 AM   #7
A1971Blazer
A1971Blazer's Avatar
Re: exhaust X Pipe
My understanding is that an H pipe serves as a balance tube to even out the exhaust pulses from one bank to the other.
I'm not sure what effect it actually has but I did put one on my LS1 swap.
Since I used the QA1 coilover suspension, I have the exhaust dumping under the bed right in front of the axle.
It's a little tight trying to get it over the rear axle and in between the track bar and the rear mounted fuel tank.
I was worried that it would drone at cruising speed but it doesn't. It's actually fairly quiet until I step on the throttle.
I'm using the Borla stainless mufflers with 2½" stainless exhaust pipe and factory 2010 Camaro manifolds, with V-band clamps on all joints for easy removal.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
