Old 01-14-2004, 04:44 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
anyone strip clear off wheels?
Not sure which place to ask this question, hopefully an answer will show up here.
Many new aluminum wheel styles have a factory clear coat on them. Anyone ever strip that off to polish the wheels? If so, which chemical did you use?
sactoC10 is offline   Reply With Quote
Old 01-14-2004, 04:48 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
I wanted to refinish a set of wheels. The shop that was going to do the work said they use a blaster with glass beads.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 01-14-2004, 10:01 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You maybe able to soda blast that also..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-15-2004, 12:28 PM   #4
sactoC10
71 DELUX
sactoC10's Avatar
Question soda blast ?
Sorry, the only thing that comes to mind is when one mf my kids shakes or drops the can before they open it.
What is Soda blasting?
Old 01-15-2004, 08:45 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
The abrasive used is soda bicarbonate instead of sand(silica) or glass or walnut shells or anything else you can shoot out at a hundred miles an hour using compressed air.
Old 01-15-2004, 08:49 PM   #6
matt67350
matt67350's Avatar
Try brake cleaner
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 01-15-2004, 08:54 PM   #7
Low69CST
we use sand paper
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-15-2004, 10:27 PM   #8
Mechanic
^What Matt Said.^
Here's the quote from Wheel Collision Center's wheel care tips:
"Never use a brake cleaner to remove grease or brake film. The solvents are too strong and will most assuredly ruin a clearcoated finish." So...if you really want the clear coat off without removing any aluminum...
Wheel collision does great aluminum wheel repair. They fixed my 15X10 8-hole Indy slot that Schwab left loose. They also strip polish and clearcoat as well.
http://www.wheelcollision.com/
Shop Labor $75, if you watch $100, if you help $125, Wisecracks-$25,
Boxjobs-don't even think about it. Yes,Cash.
Mechanic is offline   Reply With Quote
Old 01-16-2004, 01:39 AM   #9
skid
My wife had a Grand Am and after a while the clear coat started to peel off in a couple of spots. I used "Chisel " brand gasket remover to take off the rest of the clear coat to polish the wheels. It is made by Loctite. You have to be careful. It will pit aluminum if left on too long, but it works so fast that you should never pit or discolor your wheels. Just be sure to rinse well with water after the clearcoat is off!
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 01-16-2004, 11:48 AM   #10
Jace's68
Jace's68's Avatar
Pick up a can of Aircraft Stripper. I use this on wheels to remove any paint before powdercoating them.
Jace's68 is offline   Reply With Quote
Old 01-16-2004, 12:13 PM   #11
sactoC10
71 DELUX
sactoC10's Avatar
thanks...
Well I thought this thread had croaked! Thanks for the good ideas I will take note of them. I knew that there had to be a way.
JT
Old 01-16-2004, 12:16 PM   #12
joerocks
i've always used the aresol can of gasket remover, you can usually just spray it on and then rinse the clearcoat off. take the valve stem out first and use and aluminum polish and they will really shine-joe
1992 Jeep Cherokee 4.0 AUTO
1972 C10 350/350
1971 C1500 350/350
1970 C20 396/400
joerocks is offline   Reply With Quote
Old 01-16-2004, 12:43 PM   #13
boraxman
Keepin an eye out
boraxman's Avatar
I used this on my polished wheels, works great. Get it at Kragen or Autozone. Buy the gallon for $20.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 01-16-2004, 01:29 PM   #14
lock
Insert funny comment.
lock's Avatar
Thats what Ive done. Works great.
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
