Old 10-28-2024, 12:20 AM   #1
b-mac
b-mac's Avatar
Dipstick Options - Pan and Block Not Tapped
Hey guys,
Wondering what options I have for dipstick or other means of determining oil level. Block is from an '04 Rainer. Pan is the GTO style I believe. Neither seem to have provisions for a dipstick.
b-mac is offline   Reply With Quote
Old 10-29-2024, 12:42 PM   #2
Joemomma1
Joemomma1's Avatar
Re: Dipstick Options - Pan and Block Not Tapped
drill the block.
Joemomma1 is offline   Reply With Quote
Old 10-29-2024, 04:43 PM   #3
LS short box
That is so odd no dip stick. On a stock Rainer due to packaging was the dip stick was built into the oil pan? Maybe a salvage yard dive and a look at both iron blocks and alum blocks to see the placement of the dip stick.
Just a note in regards in the pic above with the oil filter the block off plate it needs to circulate oil from what I understand.
LS short box is offline   Reply With Quote
Old 11-07-2024, 06:37 PM   #4
e015475
e015475's Avatar
I have that same engine out of a 94 Rainier and the GM code is LM4. The block is physically identical to the LM7, but is cast in aluminum. I found a dipstick and tube for an LM7 in the junkyard, drilled the boss on the block and put it in with a little RTV. IIRC I had to shorten the dipstick a little to get it to work. Here's a photo of mine-
[IMG][/IMG]
e015475 is offline   Reply With Quote
Old 11-08-2024, 11:23 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I have an '05 Rainier with an all aluminum 5.3 and it has a dipstick. I didn't buy it new but I have had it for quite a few years. I will have to look at it closer and see if I can tell if it has been drilled. Interesting.....
Leon
