10-29-2024, 03:04 PM | #1 |
Junior Member
Best complete high hump floor pan
After looking at countless YouTube floor replacement videos and one stated to stay away from the LMC replacement floor. So, I figured I would ask the members on here what they consider the best and closest to OEM floor to go with.
Thanks ahead for all your opinions |
10-29-2024, 04:09 PM | #2 |
Re: Best complete high hump floor pan
Afraid I'm not much help but I bought the high hump from a vendor on this site. I'm betting they are all sourced from the same over seas supplier.
I don't recall having any big issues with the install. I bolted mine in and used caulk material to seal it to the floor. I had to add the high hump because I was running a T56 magnum. Pic after insulation installed. |
10-29-2024, 04:34 PM | #3 |
LMC, like most doesn't make anything so saying not to buy their stuff is meaningless. All of the places you buy body parts from sell stuff made in Asia by who knows who. There are not very many manufacturers and you have little chance of knowing who made a part and if it's any better than another. AMD claims to make some parts but it's hard to say if they do.
10-29-2024, 05:24 PM | #4 |
I’ve never had a bad experience with lmc
10-29-2024, 07:26 PM | #5 |
Active Member
I bought my full high hump from lmc and was pleased with it. A little banging around hear and there.
10-29-2024, 07:44 PM | #6 |
Here's a thread about floors - https://67-72chevytrucks.com/vboard/...d.php?t=848263
I do recall hearing something about the LMC floors having some problem. But, there is someone in that thread that said the LMC worked good for them. Last edited by Jason Banks; 10-29-2024 at 07:50 PM. |
10-29-2024, 07:46 PM | #7 |
You should consider gmcpauls.com
He's a board supporter and will tell you what he knows about the different floors, and tries to only sell ones he knows are good.... |
10-30-2024, 09:57 AM | #8 |
Junior Member
I saw GMC Paul's site and did see AMD and KEY stampings available
I am going to have a look at the above thread I appreciate the help from you guys and will keep on top of other members comments. KNOWLEDGE IS GOOD ! Also help me from screwing up and redoing the floor |
10-30-2024, 09:26 PM | #9 |
Active Member
Nice, I can tell you this, which i learned on here. Get lots of measurements before cutting out old oe. And some good bracing, I did mine and it went pretty good for me.
11-01-2024, 09:06 AM | #10 |
Junior Member
The LMC floor video I watched, the guy stated that it did not come with the 2 fork like stanchions attached at the front which in turn
match up to the lower firewall stanchions. I also see GMC PAUL is a Dynacorn reseller as well. I will get there advice as well. The LMC floor commentor was MAYCO Fab I believe. |
11-01-2024, 10:55 AM | #11 |
Here's the video, about 2 1/2 minutes in he talks about the LMC high hump...
https://www.youtube.com/watch?v=6D3YOXS1Pd0 |
11-01-2024, 12:37 PM | #12 |
Junior Member
Thanks. He has apparently done a few 67-72 trucks. But seeing the products from GMC PAUL I have a good feeling they will know my answer almost immediately. The other items are the lower A and B pillars as I have also seen those on YouTube with slightly different stamping bends. And like most of us who love this series of the C and K, blazer/suburban want our pride and joys as close to production line stock as we possibly can
11-01-2024, 12:39 PM | #13 |
Junior Member
E anyway as I have a numbers matching truck.
No LS swap for me |
11-02-2024, 10:25 AM | #14 |
I've got a nice original one I removed from a big block truck. PM me if you are interested.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
11-03-2024, 05:44 PM | #15 |
Junior Member
Pm sent
11-05-2024, 01:26 PM | #16 |
Junior Member
Anyone in need a OEM 67-72 high hump trans cover should PM JQ-72 as he has a BREAT DEAL for the cover which needs nothing but a quick light sanding and it's ready for paint
I don't think you will find a better deal than what Josh is offering |
