Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 10-30-2024, 02:14 PM   #1
biketopia
Help with Block Numbers
I have what I believe to be a 62-64 327 block but having a hard time confirming it. The block has the following casting number on the bellhousing, 3782870 and FI029S on the head pad. Can someone help me out in deciphering the numbers, thanks!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-30-2024, 03:17 PM   #2
RustyPile
RustyPile's Avatar
Re: Help with Block Numbers
F = Flint
1029 = Oct 29
S = engine code.. could be 327 or 283, depending on Year of production..
Locate the casting date code on the engine for year of production..
http://camaros.org/pdf/LimeBook.pdf
RustyPile is offline   Reply With Quote
Old 10-30-2024, 03:24 PM   #3
RustyPile
RustyPile's Avatar
You can decode the casting number on this site...
https://www.mortec.com/
Old 10-30-2024, 06:32 PM   #4
geezer#99
geezer#99's Avatar
If you don’t want to scroll down 110 pages then the
Suffix code S is found here.
https://nastyz28.com/gm-chevy-codes/...s-suffix-6.php
Old 10-30-2024, 09:39 PM   #5
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
3782870 casting number is for a 327. Also if you have some calipers you can measure the bore as a 283 has a smaller bore than a 327. 283 is 3.875 inch standard bore, 327 is a 4" bore. For a 283 to get to a 4" bore it would need to be bored .125 over, so its a somewhat sure way to check as well.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 10-31-2024, 09:18 AM   #6
biketopia
Originally Posted by RustyPile View Post
F = Flint
1029 = Oct 29
Looks like J283, which im decoding as October 28, 1963. But then the suffix code from the cylinder head pad being just an "S" is saying 1962 327
Old 10-31-2024, 09:22 AM   #7
biketopia
Adding pictures
Old 10-31-2024, 09:43 AM   #8
RustyPile
RustyPile's Avatar
There is no confusion, it's very explicit.. It even explains that "I" in the stamping is a "1"... Your engine stamping decodes to October 29th, which tallies with the casting date the day before.. According to the lime book, "S" could be either 327 or 283, depending on the year of production (casting date code).. The "S" is used for several years.. Go back and look at the Lime Book again.. What is the engine having the "S" designation for 1963.. That's your engine..
Old 10-31-2024, 10:12 AM   #9
biketopia
I used the chart on Nasty Z28 which indicated the only "S" designation was for a 1962 327, hence my confusion....thanks for explaining it to me like I'm 5.....
Old 10-31-2024, 10:40 AM   #10
MJN
MJN's Avatar
Sounds like its been figured out between the combination of casting number, Suffix code and casting dates but wanted to include a snippet from the Lime Book;
its a 1963 250hp, 327 from a passenger car that probably was in a 1964 model year car since it was cast in late October 1963
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 11-01-2024, 10:38 PM   #11
RustyPile
RustyPile's Avatar
Why the snarky remark?? You said you were confused so I explained how you can figure it out for yourself.. I'm sorry, but I'm not one to spoon-feed information, especially when it involves searching through a mile long list of possibilities..
Old 11-04-2024, 08:23 AM   #12
biketopia
Your response came off snarky to me. But that's the internet, hard to gauge tone via text. I do appreciate the help in fully decoding it. The confusing part was me not digging through the full list and taking the nastyz28 list a complete list. Again, I appreciate you taking the time to help myself and others learn.
