Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-30-2024, 03:29 PM   #1
hevy_chevy67
hevy_chevy67's Avatar
Painting new EDP Coated Panels
I've kind of half convinced myself to do the paint on my 70 Blazer I'm building. I've started doing some research to educate myself on the process, so hopefully this isn't a dumb question lol.
I'm not fully convinced I want to do it yet, but I have a panel that I want to paint to get my feet wet. Its a brand new rear bed floor of the Blazer so a good test area as:
1) its going to be covered in carpet so any screw ups and being painted separately really won't matter and
2) it should give me an idea if this is something I want to attempt on the rest of the truck
I've already epoxy primered and raptor coated the bottom, so I know it is in fact EDP coating (I did the rag test and none of it came off). So for the top I was planning on scuffing with some scotch brite again and then putting on a couple coats of epoxy primer. Can I go from epoxy straight to my base/clear?
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is offline   Reply With Quote
Old 10-30-2024, 04:10 PM   #2
Grounded63
Re: Painting new EDP Coated Panels
Yes, if the epoxy goes on smooth enough for your liking. You should be able to let it flash, then base/clear it. The TDS for the epoxy should give you an exact answer for top coating it.
Grounded63 is offline   Reply With Quote
Old 12-03-2024, 09:08 PM   #3
hugger6933
I have replaced thousands of panels over a lifetime and my favorite way it to sand with 220 then high build primer. That is my way I have sprayed base over a nonsanded epoxy primer but it isnt what it could be. I mean as far as slickness and whatnot. Jim
hugger6933 is offline   Reply With Quote
Old 12-04-2024, 05:05 PM   #4
LS short box
I help at a body shop a couple days a week. After epoxy priming and prior to paint they spray a sealer. The sealer makes the paint more consistent color wise.
LS short box is offline   Reply With Quote
