10-31-2024, 09:23 PM | #1 |
Active Member
Carpet
Looking for input on what needs to go between cab floor and carpet.
Joey Last edited by Dude68; 11-01-2024 at 11:25 PM. Reason: Spelling |
10-31-2024, 09:28 PM | #2 |
Re: Carpet
Depends on what you are looking for . Super insulated and quite you need some floor mat or lizard skin . I bought the ACC with mass backing and that’s all I did . It’s a big improvement over just jute backing .
11-01-2024, 07:22 AM | #3 |
Re: Carpet
I'm a Dynamat believer. This one improvement totally changed the driving experience, It is not cheap, but does so much to lower heat and noise into the cabin.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-01-2024, 02:13 PM | #4 | |
Re: Carpet
I also agree with 72c20customcamper I used DynaMat for heat/sound insulation under a ACC mass backed carpet.
Sam 1972 C10 LWB 2020 Z71 Tahoe |
11-01-2024, 04:11 PM | #5 |
Re: Carpet
Kilmat 80 mil thickness
350/th350 DNA (Chinesium) Heads Performer Intake 1905 AVS2 Edelbrock 3.42 Eaton Posi |
11-01-2024, 06:37 PM | #6 |
Re: Carpet
I used Dyna Mat like generic from Summit. I cut it to fit as needed. Then 3/8" double sided foil with jute in between the foil. Then standard carpet.
11-01-2024, 11:28 PM | #7 |
Active Member
Re: Carpet
Now that is why I am a member of this forum!!! I got several opinions on what works because it worked for them!!!
Joey |
