Old 11-01-2024, 08:56 PM   #1
gmc396
Need a New Radiator
I have a '68 GMC C2500 with a 396, granny 4 speed and AC. My radiator is leaking and with 110K miles I don't plan to have it repaired.
Looking inside, I see 4 rows in the core. The finned area measures about 29' x 17".
I'd appreciate a recommendation for a replacement.
Thanks.
gmc396 is offline   Reply With Quote
Old 11-01-2024, 09:13 PM   #2
Smitty
Smitty's Avatar
Re: Need a New Radiator
I put a champion aluminum in my ‘71. Good warranty. I’m running an automatic, with air. Also using electric fans. Not that this should make a difference. Google them. Believe you can buy directly from them.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 11-02-2024, 12:44 PM   #3
gmc396
Thank you Smitty. How was the fit; any alterations required?
Old 11-02-2024, 05:35 PM   #4
sfont66
sfont66's Avatar
X2 on the Champion aluminum radiator.
I replaced my radiator back in 2020 with the Champion EC 369,purchased from Jegs for the free shipping.
The fit is good
Back then I had a 350 with 4 speed manual transmission in my 72 C10, stock fan and shroud.
Now I use the same radiator with electric fans in front of an Ls with 6 speed manual
No overheating issues ever with either setup
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 11-02-2024, 05:44 PM   #5
Smitty
Smitty's Avatar
It pretty much just drops in. The 4 core developed a leak. After contacting them they warranties it. I ended going up the road since they are close to me in So. Cal. But they said that I could have sent a picture of the spot where it was leaking and they would have handled it that way. I ended up with a 3 core this time. The rubes on the 3 core are bigger so the flow is better. I am real happy with it. Don’t recommend anything that doesn’t treat me right. Summit is a good source as well. And their customer service is hard to beat.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 11-02-2024, 07:21 PM   #6
leddzepp
Moderator
leddzepp's Avatar
I’ve used 2 Champion radiators and been happy with the performance, price point, and fitment in my trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-02-2024, 11:26 PM   #7
gmc396
Thanks all. I'll be looking at the Champion on Monday.
Old 11-04-2024, 06:57 PM   #8
72c20customcamper
72c20customcamper's Avatar
I used a Cold Case in my 72 with the new BluePrint motor . Fit was excellent and it keeps the temps between 180-190 in the head with the stick fan and shroud . Put over 5k miles on it this summer
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-09-2024, 09:24 PM   #9
Hidesertchevy
Champion
Hidesertchevy is offline   Reply With Quote
