Old 11-01-2024, 10:11 PM   #1
Jesus5150
Smog removal from drivers side head
I have a 1971 3986336 engine that's all original from a chevy van. I want to clean it up and drop it in the c10. I ditched the carb and intake because I have a holley 4160 and torker 2 intake lying around and they're fresh.
I took the stock intake off and there's 2 steel tubes in one of the small ports of my drivers side head. What are they and how do I remove them without damage?
Jesus5150 is offline   Reply With Quote
Old 11-02-2024, 12:22 AM   #2
geezer#99
geezer#99's Avatar
Re: Smog removal from drivers side head
They’re the tubes for the hot air choke on your carb.
Over time they get stuck in the exhaust crossover by a build up of carbon.
You likely need to dig them out of there. Nothing else in there to hurt.
Old 11-02-2024, 12:24 AM   #3
Jesus5150
Wow. That's shocking. They look and feel "mounted". Thanks a lot. I'm going to move forward!
Old 11-03-2024, 01:03 PM   #4
kwmech
Yep, there supposed to be attached to the metal plate that bolts to the intake from the outside. Small chisel an hammer, start chipping away 'til they come loose. Other side looks just as clogged up
Old 11-06-2024, 09:05 AM   #5
MS66
MS66's Avatar
Careful when digging through that hardened carbon, don't let it get anywhere inside the engine, it can wreak havoc.
Since you live in WA, you will need those exhaust ports opened up for manifold heat if you do any driving during the winter. A lot of folks that live in warmer climates have plugged, or severely restricted those crossover ports to reduce the amount of exhaust heat that reaches the intake manifold. If you don't drive the truck in the winter, leave them plugged up. If you decide to go that route, you can just cut the heat riser tubes off flush, you won't hurt a thing. Personally, I would pull the heads off and clean it out, check the valves for wear at least, then new head gaskets. You don't want that hardened mess down in the cylinders, make sure the two center exhaust valves are in the closed position to keep it from going into the cylinders. Also tape over the intake ports, and cover the lifter valley well if you clean it out with the heads still mounted to the block.
MS66 is offline   Reply With Quote
Old 11-07-2024, 06:09 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If that's going to be just a stocker with a new intake and carb on it, you're gonna hate that single plane Torker intake. A dual plane would be so much better.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
