Old 01-14-2004, 08:34 PM   #1
gotmud
gotmud's Avatar
Unhappy Wiring Problem....ignition
In thread
http://67-72chevytrucks.com/vboard/s...ight=pertronix
I got info on how to wire the ignition. Now that its wiried it seems that it will not send fire to the plugs until after I release the key from start to run. Did I hook the hot wire up wrong?
I attached it to the fuse box where the radio is.
Glenn
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 01-14-2004, 08:59 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I bet the red wire is hooked up to hot in run only not hot in run and start. I believe the radio terminal is hot in run and not start.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-14-2004, 09:04 PM   #3
gotmud
gotmud's Avatar
Any ideer which terminal is hot for start and run?
Glenn
Glenn
Cumming, Ga
Old 01-14-2004, 09:19 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Don't remember but what you could do is disconnect the coil wire and with a multimeter in hand put the key in run and start and find which terminal is hot. You don't want a terminal that is hot in off or ass. as this will burn up the pertronix unit.
Old 01-14-2004, 10:52 PM   #5
Quagmire
A splendid one to behold
Quagmire's Avatar
sounds like you have the wires on the coil swapped. i had this same problem, but it's been so long, i can't remember the exact fix
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 01-14-2004, 11:15 PM   #6
gotmud
gotmud's Avatar
UGH....this is gonna be frustrating. I cant afford to burn them up. If they go the points will have to go back on. UGH...
Glenn
Cumming, Ga
Old 01-15-2004, 01:29 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
IGN UNFUSED is a hot while cranking terminal on your fuse box.
Old 01-15-2004, 02:57 AM   #8
ILIVE4TRUCKS
AKA Phillip Johnson, AKA BANNED!
Purple wire is start and I think yellow is run on the starter
ILIVE4TRUCKS is offline   Reply With Quote
Old 01-15-2004, 03:29 AM   #9
Hooter
My other Love
Hooter's Avatar
yes thats right, as for the fuseblock terminal, I wouldnt use it directly, not enough juice, but I would use it to activate a relay, so then you are sure you are getting pure voltage to you ignition system
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-15-2004, 10:10 AM   #10
mrein3
mrein3's Avatar
I'd have to look to be sure but I think I used the pink wire on the back of the ignition switch for 12V for my HEI.
If I remember correctly, on the back of the ignition Red is 12V from the battery, pink is 12V with key on or start, purple is 12V when cranking.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-15-2004, 07:33 PM   #11
Longhorn Man
That pink wire is where I normally splice in for my HEI, but I always...ALWAYS get flamed when I say this.
The fuse box will be plenty fine onless you are spinning 4500 RPM all the time, and it IS 13 to 13.5 volts there, just not as many amps.
Old 01-16-2004, 12:07 AM   #12
jorgensensc
jorgensensc's Avatar
I had the EXACT same problem!! Look at this post:
Here
Read the whole thing if you like, or read the second page at what I found to be the solution. I had the pink and brown wire backwards (even though it was hooked up according to wiring diagram.Trust Me, read this post. Hope this helps!!!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
