11-03-2024, 01:04 PM | #1 |
Improving a 283
I recently purchased a '64 c10 with a 283. I'd like to keep the engine but would like to do some improvements. I do not want to spend a lot of money, however. I will be taking the heads off later today to see how the cylinders look. No point on spending money if it needs block work.
What would you recommend? Here are some parts I'm thinking of: 305 HO heads (used) Camshaft Intake Would these be the best parts to start with? |
11-03-2024, 03:33 PM | #2 |
Re: Improving a 283
Bore it to 4 inches, making it 301.. Then big valve heads can be used.
11-03-2024, 06:29 PM | #3 |
Re: Improving a 283
I wouldn't bother pulling the heads - just do a compression test. If the compression is mostly OK, drive it and get through a few oil changes to make sure it's healthy before doing any upgrades.
305 heads will give you higher CR by a point or so...but that's not going to make a huge difference at these power levels and they're otherwise crappy heads. Avoid. Small-tube headers, low-rise intake with a small (450 CFM) 4-barrel (or Holley 2 barrel) and a mild cam upgrade would be as far as I'd go on that platform. Might as well do a stock HEI "while you're in there". With some luck, that puts you around 220+ HP at the flywheel, but with good throttle response and power. That's as far as you go without getting into the internals. |
11-03-2024, 07:32 PM | #4 |
Re: Improving a 283
2nd the HEI idea.
Are those rams horn manifolds? If so, I doubt any gain from headers would be worth the cost and hassle. Get some valve covers that accommodate a PCV system. PCV does a lot to keep the oil clean. Plus most modern carbs are calibrated with the assumption of a PCV system. If you swap manifolds, you will likely need an oil fill port on one of the valve covers anyway. A new cam implies new lifters and cam break in oil. For a manifold, some variation of an Eddy Performer/Performer RPM + a small modern 2 or 4 barrel carb. Suggest HEI + manifold/carb + PCV and run it for a while. If it runs good and doesn't leave a smoke trail worthy of a WWII destroyer, then consider doing more. |
11-03-2024, 10:55 PM | #5 |
Re: Improving a 283
I run a 283 bored 60 over which makes it a 292. I use an HEI, Edelbrock Performer EPS manifold, RV cam with a 500 cfm performer carb jetted 2 stages leaner on primaries and secondaries. I run 305 heads (416's) which are ported and polished with roller rockers. These heads keep the compresion a tad higher than stock but provide slightly larger valves and hardened seats for unleaded. I also stuck with ram horns combined with dual pipes. Keeping valve size and exhaust pipe diameter conservative keeps air velocity high for smooth spirited throttle response. I can drive all day long on a tank of gas and the motor sounds delightful when I bang thru the gears. The small motor is a bit lopey with the rv cam and the sound turns heads in town. It is powerful for its size, but better described as spirited and fun to beat on. It winds up fast but at a guestimated 250 hp it's not a serious burn out maker with 308 rear gears. It will burn out with some clutch, but that's not really what it's built for. The RV cam is a 281int/296 ex with an SAE duration of 278/288. I stuck with the rv profile because a small motor will "feel" it more than a bigger one. The 283 has a short stroke which lends to its durability and longevity. The smaller crank circle exerts less side to side thrust on cylinder walls. Think about a ratchet. A tight bolt requires a long ratchet (the long stroke motor) but, once you break it loose a shorter ratchet (the 283) can do the work fast and easy because the end of the handle travels in a smaller circle. You can spin it very quickly. Each rpm on a short stroke motor is basically less rotational distance traveled. That's the upside, the downside is sometimes you just need a big freakin' ratchet.
That's what did to one. I spent more than I would of for a stock 350 and got less power for it, but I don't care. It's just fun to hammer a 283 for all its got and I do it a lot. Last edited by AcampoDave; 11-07-2024 at 10:50 PM. |
11-04-2024, 08:27 PM | #6 |
driving is in my blood
Re: Improving a 283
If you want 305 heads then get 305 vortec heads.
Depends. There are 2" ram horns and 2.5". 2" ram horns dont flow any better then later log manifold.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
11-05-2024, 01:52 PM | #7 |
Re: Improving a 283
416 and 601 heads are excellent for a 283, and with a bit of port/chamber work will make 300 hp easily with the right cam and intake/carb. I believe 416 heads have 58cc chambers and 601 have 53cc. I have a pair of 601s that I planned on using on a 283. The smaller runners make for great low rpm response but flow well enough to make good power up top once ported. There are guys running 11s and 12s with ported 305 heads, they're not "crappy".
Check out the posts by Jeff Swisher in this thread- https://www.chevelles.com/threads/th...thread.318551/
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-05-2024, 02:04 PM | #8 |
Re: Improving a 283
Chasing a point of compression at this build level is futile, but some racers prefer small chambers as it opens up other build options - and some classes are restricted on head options so they spend a 100 hours grinding on "camel hump" or 305 heads that otherwise have horrible flow.
Comparing highly ported and modified racing heads on a racing engine to something that gets bolted on to a mild SBC isn't really apples-to-apples - especially when the big flow numbers come at .500 - .600+ lift! :-) "i felt that the flow i got from the 1.84 valve was crap on my first head" "i had 80 hours each in my 186's" - Jeff Swisher The best buy for a mild SBC are still Vortecs without question. But at this build level, still not really worth the investment IMHO - especially before making sure the engine is basically healthy. ...and regardless, a head swap without a cam swap will result in net zero power gain... Last edited by Willshook; 11-09-2024 at 03:35 PM. Reason: Add some backup :) |
11-06-2024, 12:15 AM | #9 |
Re: Improving a 283
https://67-72chevytrucks.com/vboard/...d.php?t=796471 dialing in the timing on my 283 was cheap and effective. https://67-72chevytrucks.com/vboard/....php?p=9129708 and so was dialing in my AFR. In fact that one really woke it up.
11-07-2024, 11:53 AM | #10 |
Re: Improving a 283
Thank you all for the information! It is much appreciated.
I noticed a "canister" attached to the back of the block under the intake. Is that something that needs to stay in there? I assume it's something like a pcv? Also, I would like to confirm that 305 heads will work with any sbc intake manifold, specifically the Edelbrock performer? |
11-07-2024, 12:29 PM | #11 |
Re: Improving a 283
That ‘canister’ (its a baffle) sits up kinda high and some intakes won’t clear it.
11-07-2024, 01:34 PM | #12 |
Re: Improving a 283
I think RustyPile is probably kidding, but not all 283 blocks could be safely bored to 4", even when new.
The cannister is part of a crankcase ventilation system, from breather to road draft tube. Google is your friend to learn about it. After a compression check, I'd simply change the spark plugs, oil & filter, and try to start the engine. If no excessive valve train noise, drive it for awhile. Might want to check the carb internals, too. As for 305 heads, #416 and #601 castings from the Z28 HO engines probably work better than stock 283 heads. There's talk about these on Chevy forums like NastyZ28 and GBody.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
11-07-2024, 07:24 PM | #13 |
Re: Improving a 283
Vortec's require specific intake. TPI 305 heads like the castings listed above are standard intake pattern.
11-07-2024, 09:41 PM | #14 |
Re: Improving a 283
It has been my understanding that the 305 vortec engine did not use "vortec" heads per se as found on the larger engines. Even though GM began calling the whole 305 motor a vortec, the heads were were not truly "vortec heads".
11-07-2024, 10:16 PM | #15 |
Re: Improving a 283
Vortec heads will need center bolt valve covers in addition to a Vortec specific intake. The valves will be shrouded in a small bore 283 and compression will drop so they won’t flow as well as they would on a 4” bore, and the improved chamber design is kinda wasted at a lower compression point.
The 416 and 601 heads flow better than the old 283 Power Pack heads, have small chambers to keep compression up, and use standard intakes and perimeter bolt valve covers. No downsides to using them on a 283. With mold port work they’ll make really nice power. Vortec 305 heads do not carry over the same port and chamber design advantages that 5.7 Vortec heads have. I bought a 283 a few months ago and just went over researching all this myself, to the point of picking up a set of 601 heads. Since then a neighbor offered me a complete running Vortec 5.7 for free, and a friend has a large journal 327 crankshaft so I might end up building a roller cam 327 instead.
11-07-2024, 10:25 PM | #16 | |
Re: Improving a 283
Edit: On my stock 283 I left that baffle in there and put a pcv valve with a grommet in the old draft tube hole. I've seen other threads where they sneak a pvc hidden on the back of the valvecover by modifying it, but never tried it. Last edited by AcampoDave; 11-07-2024 at 10:36 PM. |
11-07-2024, 10:36 PM | #17 |
Re: Improving a 283
I got out of the military in Feb, 1966. I immediately made plans to "restart" my racing endeavors. It was a common knowledge that 283 blocks made before 1959 could be bored .125" producing a 4" bore. The rules at the time were a "loose" weight per cubic inch limit. Actual displacement wasn't a factor, only the engine's designed displacement.. In the class I competed, stroking wasn't allowed.. The formula they used gave the 283, aka 301, a tremendous weight break over a 327. As I stated, it also allowed much larger valves. Boring a 327 to even .060" over was a risky task.. I built for myself and fellow racers, numerous 301s using 283 blocks.. I still have a 4" 283 block... It's a pre-'58, as there are no motor mount bosses in the side of the block..
11-07-2024, 10:55 PM | #18 | |
Re: Improving a 283
11-08-2024, 11:40 AM | #19 | |
Re: Improving a 283
Several years ago I built a 327 for a 55 Chevy sedan. I used a 350 "010" block, 307 crank, Brodix IK180 heads, and a moderate solid lifter cam. Along with a Muncie 4-speed, it was like I was a kid again! Your large journal 327 crank was a real find. They were only made for what, a year or two? I almost bought a forged 327 crank, but it would have been a real budget buster. Have fun!
11-08-2024, 11:55 AM | #20 | |
Re: Improving a 283
That said, the Holley/Weiand 8120 Street Warrior may be a better choice, because it's a newer design with lots of attention paid to equalizing runner-to-runner flow.
11-08-2024, 05:41 PM | #21 | |
Re: Improving a 283
I wanted to go to 4", just to say I had a 301, but the machinist talked me out of it, so it became a 292. With Power Pack heads and stock valves, a 301 probably wouldn't have worked any better. Wish I could remember all the parts, but I do recall it having domed pistons and some kind of Isky or Erson cam. Oh, and Hedman 4-into-2 headers!
11-14-2024, 06:32 PM | #22 |
Re: Improving a 283
Soooooo....Mr Backpayne, any updates?
11-14-2024, 07:16 PM | #23 |
Re: Improving a 283
Nothing as of now. I've decided to pull the engine and take it apart to see how the internals are. I want to make sure everything checks out before investing in a cam, intake, and carb.
My cherry picker will not lift the engine/transmission high enough, so I'm taking the front panels/grille off. Soaking the bolts in PB blaster right now. |
11-14-2024, 07:42 PM | #24 |
Re: Improving a 283
If you've taken it apart, you're going to have to rebuild it.
At that point, you might as well just pick up a junk 350 and build that. Same price. |
11-14-2024, 07:55 PM | #25 |
Re: Improving a 283
I'm just taking the heads off and oil pan to clean it out and replace the gaskets. There's some sludge in the heads and I want to make sure the oil pickup is clean. If the cylinders are scored I'm going to get a different engine.
