Old 11-03-2024, 01:25 PM   #1
kna4977
Negative Battery Cable Secondary Ground?
Have a screw hole on the inside of the passenger fender. I’m assuming this is for the secondary ground wire that comes off the primary cable. Anyone know what hardware (screw or bolt size washers etc?) is used to attach it? Attached is a picture of the hole.
kna4977 is offline   Reply With Quote
Old 11-03-2024, 04:31 PM   #2
72SB
Re: Negative Battery Cable Secondary Ground?
I just used a 1/4 nut drive sheet metal screw with a star washer
The relays are for my headlight relay harness
72SB is offline   Reply With Quote
Old 11-04-2024, 07:45 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I don't have the info handy, but I'm mostly certain it is a. Qtr.inch thread described above. The same tap screw found with all the ground straps, and wires for taping sheet metal.
takes a ground washer as described too.
I believe its a side mount battery cable feature.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
