Old 11-04-2024, 09:38 PM   #1
MS66
MS66's Avatar
Synchronized Tree speed
My truck is a '68 C-10 with a 250 and non synchronized 3 on the tree. I have a question about what 1st gear synchronized 3 speed gear box will be a direct swap. I want to keep everything the same(or very close to it) on the column shift linkage. Can someone steer me in the right direction where I might can find this information, my google powers aren't bringing any useful info yet. Thanks for any help.
FWIW, the 3 speed in my '69 G-10 van has synchronized 1st gear, it is spoiling me. Same engine as C-10.
EDIT: I found some useful info. My truck has a light duty Muncie 318 non synchro, seems the Saginaws are synched. Are all the Saginaw 3 speeds synchronized in first gear?
I need to rephrase my question, what all will I need to swap a Saginaw in place of the Muncie 318? Is it a feasible swap?
Found some more stuff. This is a pic off the internet of the transmission in my truck, Muncie SM318. OAL from bell housing to end of output shaft is 16.5".
Member 68gmsee on here did this exact swap long ago. He hasn't been on here since '22. Not a good sign. Hope all is well.
Last edited by MS66; 11-05-2024 at 12:16 AM. Reason: Found some info I was looking for
MS66 is offline   Reply With Quote
Old 11-06-2024, 08:10 AM   #2
bhap
bhap's Avatar
Re: Synchronized Tree speed
I swapped from a Muncie to a Saginaw OD three speed a few years ago. Depending on which Muncie you have - long or short - you may need to shorten your driveshaft. Mine was a longer Muncie and driveshaft would have fit, but needed a different front coupling to match the output shaft. It should bolt right in. Other than front of driveshaft, I had to lengthen one of my shift rods about 3”. My truck is a 62, but since yours is a 68, shift rods should be available in the junk yard. Good luck!
bhap is offline   Reply With Quote
Old 11-08-2024, 12:48 AM   #3
MS66
MS66's Avatar
Are the car 3 speed Saginaws the same as a Saginaw that came in the C-10s? I found a Saginaw out of a '73 Olds Omega behind a 250 six, would that be a good swap into my '68 C-10?
EDIT: I see the car and truck transmissions have different front bearing retainers listed, is there any other differences I need to address?
Old 11-09-2024, 11:46 AM   #4
bhap
bhap's Avatar
I think the only other difference is the way the trans bolts to the bell housing. I think the lower holes on the truck trans are threaded and the car are not. You just need to use a longer bolt and a nut instead. Just make sure you clear the flywheel.
Old 11-17-2024, 08:26 PM   #5
karlbenz
I got one out of a 75ish 3/4 ton. it was synchronized
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
