Old 01-14-2004, 09:21 PM   #1
72gmcshorty
72gmcshorty's Avatar
2wd vs 4wd frame
Whats the difference between the two frames (i understand the front difference, what about the back?)
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-14-2004, 11:01 PM   #2
Mike C
Mike C's Avatar
Not sure on a Blazer, but on the trucks the spring centers are 40" on 4x4 and 42.5" on 2x4. The rails are splayed and not straight.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-15-2004, 12:47 AM   #3
Gee_Emm
Here is the backl half of my 2wd. Not sure but I think the 72 2wd frames might be different then the rest of the 2wd frames
Gee_Emm is offline   Reply With Quote
Old 01-15-2004, 08:13 PM   #4
6772king
6772king's Avatar
here is a pic of my 71 blazer 4x4 frame kinda hard to see
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 01-15-2004, 08:22 PM   #5
6772king
6772king's Avatar
here is my 72 jimmy frame also notice how the 2wd frame flares out over the rear and the 4x4 doesn't as for the 72 2wd frame I thought the only diff was the rear bumber mounts???
Old 01-15-2004, 08:27 PM   #6
6772king
6772king's Avatar
oops forgot the pic
Old 01-15-2004, 08:55 PM   #7
raggedjim
raggedjim's Avatar
Most obvious is 4x4 has leafs and 2wd has trailing arms and coils.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 01-15-2004, 09:34 PM   #8
jamie72
jamie72's Avatar
hey sean you need to stop posting pics of my yard...lol
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 01-15-2004, 11:20 PM   #9
Gee_Emm
The 72 bed floor has the notch out on the rear cross member which leads me to believe that the frame angles up at the back, did the 71's come this way also?
Old 01-16-2004, 08:11 PM   #10
6772king
6772king's Avatar
the 69-714x4 frames and 70-71 2wd frames ended right behind the last body mount so the rear cross member didn't need to be cut out (the frame ended before the rear cross member) so the 72 was the only year that the bumper mounted directlly to the frame. panel's and subs' were the same way' I'm not sure about pickup's
Old 01-16-2004, 08:14 PM   #11
6772king
6772king's Avatar
another view
