Old 11-09-2024, 10:18 AM   #1
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Clutch Fan Install getting mucho frustrated
Could someone break it down the assembly order for this? I'm thinking I need studs because I cannot get the bolts in from the fan side o from the water pump.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 11-09-2024, 10:27 AM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Clutch Fan Install getting mucho frustrated
Save yourself mucho frustration and get the studs. It's 10 times easier.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-09-2024, 01:23 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
This. The last time I changed my fan clutch, I didn't know about the studs. Fiddly but I eventually got it. Told myself if I ever do it again, I'll get the studs.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-09-2024, 01:49 PM   #4
leddzepp
Moderator
leddzepp's Avatar
I use studs on every vehicle I own, makes life way easier.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-09-2024, 02:37 PM   #5
Oregon 1967 GMC
Copy that. Thank you I'm getting studs.
Hey man
Old 11-09-2024, 03:01 PM   #6
chewychevy67
I used studs on my 67 327 as well. Much easier to line up the clutch under the shroud
chewychevy67 is offline   Reply With Quote
Old 11-09-2024, 03:17 PM   #7
54blackhornet
54blackhornet's Avatar
Napa has a kit with everything you need.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 11-09-2024, 07:01 PM   #8
Dashman
Active Member
You're not putting that spacer back, right? I believe those are only for flex fans replacing thermo clutch fans.
Dashman is offline   Reply With Quote
Old 11-09-2024, 08:44 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good point, that spacer should not be needed. The real test is whether the fan blades are roughly half-in, half-out of the shroud opening.
- Mike -
RIP El Jay
Old 11-10-2024, 03:12 AM   #10
Oregon 1967 GMC
I do need that spacer to reach half in half out position in shroud. Hope i can find studs that long. I'll look at NAPa because O O'Reilly only had two inches
Hey man
Old 11-10-2024, 08:51 AM   #11
Oregon 1967 GMC
I ordered this from Summit. Hope it works
Hey man
Old 11-17-2024, 12:20 PM   #12
Oregon 1967 GMC
It didn't work. Going to augment shroud
Hey man
Old 11-17-2024, 01:35 PM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I couldn't tell by the pic, and don't have the particulars off the top of my head.... But is there a chance you have a short water pump, and a long water pump might put everything right?
EDIT: This might help:
- Mike -
RIP El Jay
Old 11-17-2024, 02:45 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ Interesting pic. My '70 BBC has a short water pump.
~Steven
Simi Valley, CA
Old 11-17-2024, 04:14 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Well, the OP's '67 should have a short original WP -- but over the years, things can change.
- Mike -
RIP El Jay
Old 11-17-2024, 04:59 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
What's worse is that my fan clutch is about 1/2" from the radiator. That's the severe duty clutch, though, which has fins that stick out pretty far past the fan mounting flange. I ended up just making a shroud from a piece of aluminum strap.
We haven't seen the OP's shroud. Maybe the deeper 4WD shroud would work?
~Steven
Simi Valley, CA
Old 11-17-2024, 08:24 PM   #17
I agree. I've tried both ways and studs are definitely the way to go.
Old 11-18-2024, 01:59 AM   #18
Stanco
Stanco's Avatar
If you do a search for 5/16 studs 1.25 inches long you will find several with the fine thread end longer than the course thread end. This is not ideal for a fan clutch instillation.
AMK has the correct hard to find studs available but has a minimum order of $30.
Along with the studs I also bought some correct water pump, alternator, and power steering pump bolts to replace some ugly hardware store bolts.
https://www.amkproducts.com/bulk-fas...oduct_ID=11003
Stanco is offline   Reply With Quote
Old 11-18-2024, 07:57 AM   #19
Oregon 1967 GMC
I have a long water pump.
Hey man
Old 11-18-2024, 10:35 AM   #20
72c20customcamper
72c20customcamper's Avatar
Something is strange then . The long water pump would push the fan further into the shroud . I have this problem on my 72 it had a later model engine with a long water pump with the associated accessories brackets. The fan is not half in and out it’s completely inside the shroud . I’ll post a pick later have to go out to the truck
Edit for pictures:
It’s not optimal but the truck has never overheated even pulling the trailer .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-18-2024, 11:06 AM   #21
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Clutch Fan Install getting mucho frustrated
https://www.ebay.com/itm/27644031344...Bk9SR9La9fznZA
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-18-2024, 02:27 PM   #22
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Agreed, pics would definitely help, and a deeper 4x4 shroud might be the answer.
FWIW, the OEM shroud on my K20 is right at 9" deep front-to-back.
- Mike -
RIP El Jay
Old 11-18-2024, 02:58 PM   #23
Oregon 1967 GMC
It may be because my 400 sbc is back against the firewall. My plug wires literally rub against the firewall. Not sure maybe because I used the same motor mounts that my straight six 250 had.
Hey man
Old 11-18-2024, 03:04 PM   #24
un4gvn!
un4gvn!'s Avatar
Carburetor studs work also and they come in different lengths. Some come useing hex key to install.
un4gvn! is offline   Reply With Quote
Old 11-18-2024, 03:20 PM   #25
Classic Bowties
Always on the hunt...
^ ^ ^ After ten days, 800 views and 25 post in... With that above added info, you have answered/solved the root of the mucho clutch fan issues that you are having on your own. Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
