95 K2500 won't engage 4WD
I did a search first, honest I did! Thought I had asked this question here before.
Anyway, we have a '95 K2500 with tons of mileage on it. It won't shift into 4WD anymore. I can put it in and it appears to be in, but won't engage the front axle. What is going on? Truck: 1995 K2500 (gas) 350 automatic. problem: won't engage front axle in 4WD. Any ideas???? |
Re: 95 K2500 won't engage 4WD
most likely your axle actuator, or the 4wd indicator switch on the transfer case,
i just replaced both to go wit my newly rebuilt t-case. |
x2 on the actuator.....
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6 lift SAS 1999 Chevy CCSB 454/NV4500 4 SAS 1999 GMC Yukon stock SAS 6" |
#4 | |
![]() Quote:
Looked on the 'Tube and found a video! Very cool. Well looks to be easy enough to do. It's just a matter of getting under the truck. Looks simple enough that even an ignoramus like me can do it! https://www.youtube.com/watch?v=dv6pUKKOAqI Last edited by studeclunker; 11-11-2024 at 02:32 PM. |
![]() ![]() Join Date: Jan 2005
4WD quit engaging on my '89 K1500 recently. Replacing the actuator solved the problem for me. I got part number 2FWDA1 from O'Reilly. It screws into the top center of the front axle housing. It took about 10 minutes to replace it.
https://www.oreillyauto.com/detail/c...or/mpi0/2fwda1 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Does this K2500 use an electric switch to engage the front axle? Just curious as my 99 K2500 makes use of a manual shifter for the transfer case.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
All about them Ks
![]() Join Date: Jun 2014
Pete, the 98-99 trucks use a servo style electric actuator that is quite a bit more reliable than the earlier thermal actuators.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
#8 | |
does not matter if your t-case is electric shift or manual shift, the actuator just engages your front axle. my kid's '96 has the thermal one and after seeing how fast it engages he now wants to upgrade to the electric one. i think the reason the thermals are not so good is because it has to stay "on" whenever your in 4by whereas the electric is off and on- not always on which prob prolongs the life of them |
Carpe manana
Thanks guys. I get some brief gear grinding when engaging 4wd, but it engages
| Bookmarks |
