Old 11-12-2024, 07:54 PM   #1
crazyjeenyus
crazyjeenyus's Avatar
Fuel Filler Housing Design
Hi All,
We're working on a '65 c10 father-daughter project and thought I'd include a drawing of the fuel filler housing we designed (see attached PDF below).
Please ignore the welds as our intent was only to tack the seams. We also installed it higher than the bed floor because we are going to install wood over top what is left of the original bed floor -I feel like if we take the bed apart, it will cost more than I want to invest to put it back together.
Because of this, we installed the Blazer-style fuel tank without removing the box. Here's a video link in case your interested in doing the same thing:
https://www.youtube.com/watch?v=MQ_JNM3lkpA
The parts we used:
Blazer style fuel tank: Classic Performance Products Fuel Tank Conversion Kit 21 Gallon OEM-Style Chevrolet C10 1967-1972
Classic Performance Products: 6772FMT-K
Filler with Keyless Cap: ISURE MARINE 1-1/2"(38mm) Boat Fuel Deck Fill/Filler with Keyless Cap with Screws, Marine Mirror Polished 316 Stainless Steel Hardware Angled Neck for Boat Yacht Caravan
Air breather elbow (I drilled and tapped a hole in the filler): Podavelle 1/4 NPT Male to 3/8 Hose Barb Fitting Adapter 90 Degree Aluminum Black
Fuel filler neck: Gates 24702 Flexible Gasoline Fuel Filler Neck Hose-3' Length, Inner Diameter 1 3/8"
Tank vent valve: Holley 19-174 Remote Mount Vent Valve
'67 c10
'65 c10
crazyjeenyus is offline   Reply With Quote
