350c transmission leak at speedo cable.
My transmission is leaking around speedo bullet. The center o ring is sealing fine, it is leaking around the outside o ring. I have replaced the entire bullet, both o rings and the speedo gear twice and it is still leaking. I’m wondering if the o ring might be slightly under sized. Does anyone have a good source for the correct o ring? Or any other ideas why this may be leaking?
| Bookmarks |
