![]() Join Date: Feb 2022
Correct AC grommet
On my 72, there is a odd sized grommet hole for the ac cable in the firewall above the evaporator box. I think it is 7/8". It is a single hole grommet with only the control cable passing through. The AC vacuum and wires pass through a hole at the tunnel. The firewall hole for this cable grommet is larger than the 3/4" holes used for single wire pass like the tach and aux battery. But it is smaller than the holes used for oil pressure or windshield washer tube's. Does anyone know a source for this odd sized grommet?
#2 | |
![]() Join Date: Dec 1999
Re: Correct AC grommet
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
![]() Join Date: Apr 2016
That is interesting. I also could not find that grommet, so it's good to know it's available for next time. To contribute to the bubble gum and bailing wire repair category I found a rubber washer at the hardware store and superglued it to metal surrounding the hole.
Thank you Richard. Shape seems correct as well. I'll give it a try.
| Bookmarks |
