Old 11-16-2024, 06:19 PM   #1
kna4977
POA schrader/check valve?
On the side of the POA valve is the low pressure port that you charge through. I've read that this is not a typical schrader valve, but is some sort of check valve? Are replacements available or do you have to get another unit? If available what am I looking for what's it called and where can I find?
kna4977 is offline   Reply With Quote
Old 11-16-2024, 09:33 PM   #2
Sheepdip
Sheepdip's Avatar
Re: POA schrader/check valve?
This may help
https://autoacsolutions.com/products...oe-appearance/
Sheepdip is offline   Reply With Quote
Old 11-19-2024, 02:18 AM   #3
Richard
Originally Posted by Sheepdip View Post
That is not a POA valve. Just this https://autoacsolutions.com/products...-update-valve/ made to look like a POA. Both pieces are a connector tube with ports to convert to a cycling clutch system, eliminating the POA. Not what I am doing. Not sure what you are referring to kna4977. There is a service port on the POA and it uses a standard schrader valve.
Richard
Old 11-19-2024, 11:20 AM   #4
kna4977
This is what I’m referring to. From this it sounds like it’s not a normal schrader valve. I would like to replace the valve if possible but I need to know exactly what to replace it with and where to get the part. My POA valve is good. I think the schrader valve in the POA service valve may leak, but only if the 134 adapter is removed. I would like to eliminate the 134 adapter so it appears completely original.
https://www.autoacforum.com/viewtopi...ad6f2738#p7180
Old 11-19-2024, 12:18 PM   #5
Sheepdip
Sheepdip's Avatar
Opps my bad!
Old 11-20-2024, 12:47 AM   #6
Richard
If I am reading and understanding correctly, that article is referring to a different port on the POA. The service port uses a standard schrader.
Richard
Old 11-20-2024, 08:51 AM   #7
kna4977
Any idea what size schrader?
Old 11-21-2024, 11:53 PM   #8
kna4977
bump
