Old 11-17-2024, 07:00 PM   #1
willem445
willem445's Avatar
Manual Clutch Z-Bar/Bellcrank Assembly Question
I cannot find a decent diagram of the manual clutch assembly for these trucks (SM465).
I've got mine completely disassembled but I'm confused as to how it's supposed to go together.
The frame side makes sense to me. There is the ball and two plastic bushings go on each side of the ball. The ball & bushings then slide into the bellcrank and are secured with a clip. The ball then mounts to the frame bracket.
How is it supposed to mate to the engine mounted stud/ball?
Does the bell crank just directly slide onto the ball? Or is there supposed to be more of the plastic bushings? When disassembling, there wasn't much on the engine side, just the one plastic bushing on the outside, but I don't see how without a clip or anything holding it inside the shaft, that it would just push out with the grease.
Here is a picture of what I've purchased from classicparts.com:
The square family:
1980 Chevy K20 Farm Truck
1977 Chevy K20
1986 Chevy K30 3+3 Dually
willem445 is offline   Reply With Quote
