Old 11-18-2024, 03:14 AM   #1
skokie
skokie's Avatar
Hood insulation 68 C10
Did our trucks come with hood insulation? Just curious if my 68 C10 had it in its younger years.
Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-18-2024, 09:24 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Hood insulation 68 C10
I doubt it. My K20 was just 5 years old when I bought it. There's no indication that it ever had hood insulation. Be interesting to see what others say -- maybe as an option?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-18-2024, 09:32 AM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
Not from the factory as far as i know.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-19-2024, 12:52 AM   #4
MikeB
MikeB's Avatar
I've been thinking about adding some to my 69 C10 for sound insulation more than anything. A buddy of mine used this on a 37 Chevy primarily to protect the paint. https://store.dynamat.com/products/the-hoodliner
Hard to say if it deadened sound any, but I will say it's still looks like new after 5-6 years and hasn't come loose at all. Might need two packs though to do a truck hood. Not cheap!
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-25-2025, 12:50 PM   #5
K10-Kansas
K10-Kansas's Avatar
I think putting on some sound deadening material could make the drive a little quieter, and of course if your putting it on the hood, it would need to be heat resistant so it would probably be the same material as a heat shield. Not that shielding the hood from heat would be its purpose. Has anyone here done it and can report on results?
1971 C10 body. 76 4x4 chassis cut to short frame. Crate 350 2nd Gen small block. 4BBL Holley 4160. 4L60 transmission. ~ James
K10-Kansas is offline   Reply With Quote
Old 11-25-2025, 05:10 PM   #6
LS short box
I haven't used Dyna Mat on the inside of the hood. But I have used similar products in my hot rods.
First a layer of Dyna Mat like stuff for the first layer on the floor. Then double sided foil with 3/8"to 1/2" of jute insulation between the foil. Then the carpet. Zero heat in the cab with headers.
On my 71 Corvette project to protect the fiberglass tub above the headers I used some insulation material from DEI. It's metal of sort that has kind of a waffle pattern on both sides with fiberglass insulation. It's bright silver but I bet you could paint it with the proper prep.
LS short box is offline   Reply With Quote
Old 11-25-2025, 07:13 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
Thanks!
No. And I've had my '68 C/10 Stepside since June 1973.
On a '67 K/10 Suburban I ran from 1993 to 1998, a PO put some rubber ripple/silver material under the hood -- over a 454. It was decomposing. He lived in the PHX area -- where it gets even hotter than Tucson. I guess the insulation was for noise control.
