Old 11-23-2024, 09:45 PM   #1
Extended Power
Extended Power's Avatar
Why does the AC come on when the heat is on max?
Vintage Air gen IV.
Using a DDC-4000 controller.
New install.
Weather just turned cold and the wife and I took the truck out for one last rip for the year.
So I turned the temperature up to max, 32* and it wanted to max out the fan and turn to auto, so I backed it down to 31* and manually turned the fan down a bit just so I had control.
All a sudden, the system switched the AC on and started blowing old air???.
Turned the AC off by pushing the button.
Only stayed off for about 30 seconds and turned the AC back on again!
This controller had a bad wire that was loose in the harness plug, and I bought a new harness as my hands are too big to work with such small, delicate wires.
I was thinking of trying to do a "calibration" again and try it, but the truck will not be running for months now...
Any other ideas of what it might be?
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 11-24-2024, 12:22 AM   #2
Hidesertchevy
Re: Why does the AC come on when the heat is on max?
It pulls the moisture out of the air.
Hidesertchevy is offline   Reply With Quote
Old 11-24-2024, 01:50 PM   #3
Richard
Seems kind of odd operation to me. Typically the compressor would be turned on in the defrost cycle for reasons mentioned above. But not the max setting. In stock systems utilizing outside air the max setting would shut off outside air and recycle cabin air. i would contact the manufacturer to confirm operation.
Richard
Old 11-24-2024, 04:23 PM   #4
weq92f
weq92f's Avatar
That's a fancy schmancy VA unit compared to mine but...I think the Gen IV had already separated the evaporator and heat core rather than using a single component for both. My earlier unit uses a single unit for both and allows a blending of the two via a sliding scale from hot to cold...which basically cycles the pump to achieve the desired blending.
I believe the later models allow this blending the same way, but it's accomplished with air blend doors. If you have the heated water inside the unit and the A/C compressor pressurizing the system simultaneously and all you get is COLD vent air, I suspect your system is malfunctioning if indeed you've got it set to C rather than F and you really are going for heat!
Whether its a software or a hardware fault, something isn't right!
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
