Old 12-05-2024, 08:30 PM   #1
skokie
skokie's Avatar
700r4 lockup. How many ways?
Hey
The title says it all. 700r4 lockup. How many ways are there to achieve this. I have heard about the TCI switch and changing a brake light switch, are there other ways?
Thanks everyone!!
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-05-2024, 09:45 PM   #2
Smitty
Smitty's Avatar
Re: 700r4 lockup. How many ways?
I have mine through a toggle switch. Currently cruise around town most often, not needing to lock it up. When it was rebuilt had my mechanic put in the toggle switch.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 12-06-2024, 10:49 AM   #3
Rickysnickers
Rickysnickers's Avatar
Here's what I used, https://www.classicindustries.com/pr...B&gclsrc=aw.ds
Old 12-06-2024, 11:08 AM   #4
Myself
I just did one for my buddies Chevelle. I put an early 80's VB into a '90 case, with other required mods. No control needed, lockup is completely automatic by means of a hydraulic valve that IS NOT in later valve bodies.
Myself is offline   Reply With Quote
Old 12-06-2024, 01:00 PM   #5
truckster
truckster's Avatar
Does it unlock with the brake switch?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 12-06-2024, 05:26 PM   #6
MARKDTN
If I recall correctly on my '83 K20 it had ignition power to a vacuum switch and then through a brake switch to the converter lockup + side. The ground is provided by a 4th gear switch on the transmission valve body. So if you are in 4th you get a ground. Then if you are not on the brake and have sufficient manifold vacuum it will lock up. Lose any of that and it unlocks the converter.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-06-2024, 10:14 PM   #7
Rick Bollinger
I used the B&M lock up kit. Wired through the converted brake switch. It automatically locks up at a speed that you set. Then unlocks when you touch the brakes or drop below set speed. What I don't like is that it wont unlock when passing. When I get it back on the road I am going to also run it through a vacuum switch. So that when you accelerate hard and vacuum pressure drops it will unlock as well.
https://www.summitracing.com/parts/b...+5b9ad3715b1a7
Rick Bollinger is offline   Reply With Quote
Old 12-07-2024, 12:11 AM   #8
Myself
If you still want it wired in for safety or panic stops then you certainly can wire the TCC in. Otherwise the hydraulic valve is ONLY inline after there is pressure signal from 4th gear and likewise causes an UNlock when there is no 4th gear pressure signal.
Old 12-07-2024, 04:41 PM   #9
weq92f
weq92f's Avatar
I've got the updated brake switch (a second circuit) wired to UNlock with brake application. It's not great exactly but it does get the job done. The TC locks immediately after shift into 4th and stays that way unless I give enough throttle to downshift to 3rd or 2nd. I can hold steady OD acceleration and tap the brake pedal and see the RPM go up maybe 200 and then right back down.
Not ideal...I've read on here of at least one member using a vacuum switch and delay circuitry to add some more smarts into it though so as vacuum goes toward zero, some threshold is reached were the TC will UNlock and stay that way for a short period...maybe 10 seconds or something.
The kit above seems to also be reasonable IMO.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-07-2024, 09:07 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
b&m lockup switch
https://www.summitracing.com/parts/b...YaAlYmEALw_wcB
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 12-09-2024, 11:50 AM   #11
dennislbrooks
dennislbrooks's Avatar
I went like Smitty, a switch and mine knocks off with the brake. Depending on your gearing and tire size, I found I really only want lockup out on highway driving. If I have my push button switch engaged, I have a green LED that comes on also. The brake switch will kill the LED also.
Your situation may be different. I drive sometimes in D and not using the OD at all. This also prevents lockup.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
