Old 12-06-2024, 03:05 AM   #1
lil hoodlum
lil hoodlum's Avatar
Question on flushing cooling system
My orginal Champion aluminum radiator has developed a small leak. I used JB weld in an effort to seal up the leak. No worky, so I purchased another Champion radiator to replace it.
I'll also be changing my heater core and thermostat while I have the coolant out.
I'm curious about using the cooling system flushes or just flushing out the system with a garden hose stuffed down the hole in the intake manifold where the thermostat housing is, while the radiator is out.
Are the cooling system flushes worth it?
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 12-06-2024, 09:51 AM   #2
1970cstblazer
1970cstblazer's Avatar
Exclamation Re: Question on flushing cooling system
The normal parts store flushes can break up deposits that regular garden hose flushing will not get. If you really have a neglected system, muriatic acid will clean the heck out of the jackets, but are tough on core plugs and anything that is the least bit weakened by corrosion and age. Also stinks and can be harmful to skin.
Old 12-07-2024, 10:59 AM   #3
Chevy nutcase
Chevy nutcase's Avatar
Using parts store flush is fine and can be done multiple times for bad build up. I wouldn't use Muratic acid for any reason as it destroys aluminum rapidly and any benefit is heavily outweighed by the damage it'd do
Chevy nutcase is offline   Reply With Quote
