Old 12-12-2024, 12:46 PM   #1
cag
350 roller cam engine, what yrs???
new to this small block stuff, what yrs had a roller cam, and what is the deal with the vortec heads?
thanks!!
cag is offline   Reply With Quote
Old 12-12-2024, 01:23 PM   #2
Accelo
Accelo's Avatar
Re: 350 roller cam engine, what yrs???
GM first began installing roller cams in some Chevrolet small-block, V8-equipped cars in 1987. But OE roller-cam installations in trucks didn't occur until 1995.
Vortec heads caused a huge jump in airflow and swirl, bumping the HP significantly. Vortec heads also require a matching intake manifold to work correctly.
If I were sourcing an engine, the later, the better. You will get a better-sealed engine with a one-piece rear main seal and center-hung valve covers that don't leak. You will also get higher-flowing heads and a roller cam. Old is for restorations, in my humble opinion.
Accelo is offline   Reply With Quote
Old 12-12-2024, 05:05 PM   #3
Tom
driving is in my blood
Tom's Avatar
Nope, and yet they are always covered in oil and dirt.....
Old 12-12-2024, 05:26 PM   #4
Willshook
A few additional comments.
Most late model GEN I roller cam blocks don't have the hole for a mechanical fuel pump pushrod, requiring either an electric pump or a machine shop with the correct jig to drill, ream, and hone it.
Vortec heads are great, but stock they are lift-limited to about .460 or so. This is easily addressed with some machine work and/or valve spring replacement and honestly there's not a ton of flow with more lift. Aftermarket versions that aren't lift-limited are readily available.
Keep in mind the intake is different.
You probably know all this, but better to find out before you start bolting stuff together...
Willshook is offline   Reply With Quote
Old 12-13-2024, 03:45 PM   #5
Dead Parrot
SBCs are wonderful for being fairly compatible parts wise over the entire lifespan. Vortec heads will happily fit on a block of the 60's assuming bore sizes match. HEI dizzy in a engine that came original with points. Late model serpentine belts setup on early model engines. Or vice-versa if desired.
You need to double check details like Willshook mentioned about the fuel pump pushrod but generally the parts play well together.
Dead Parrot is offline   Reply With Quote
Old 12-15-2024, 10:17 PM   #6
truckster
truckster's Avatar
True, but none of that gives you a roller cam. I highly recommend the L31 block (casting number ends with 880). You get the roller cam and one-piece rear main seal. If you get one out of a used truck look for one with a block-off plate for the fuel pump - that signals that it's bored for a mechanical fuel pump rod. However, the cam may not have a fuel pump lobe. I got mine from a 98 1 ton and put a HT383 cam in it when I rebuilt it. That cam does have the fuel pump lobe.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-16-2024, 08:41 AM   #7
cag
Thanks for the help! i will look for the L31, swap the cam and intake and see what it does!
