Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 12-15-2024, 03:38 PM   #1
weq92f
weq92f's Avatar
GM DCT tranny maintenance
Learned today GM requires an aggressive maintenance schedule for its DCT currently in the C8 Corvette. There are two items that have different schedules: the fluid and the filter.
Fluid: 3 years or 45k 1200US
Filter: 7.5k, 22.5k and at 45k miles etc 770US
Fluid and Filter 1400US
Prices are dealer charge for service.
Parts are expensive: fluid=500, filter=200 (retail)
The fluid has a 3 year shelf life! However once installed, it’s good for 3 years regardless of its current shelf age!
I find that fascinating indeed.
EDIT: what brought my attention to this is that GM sent corvette owners a letter reminding them of the importance of keeping up with the schedule and that future warranty claims require adherence.
Things that make ya go hmmmm.
If anyone buys one of these used, now or over the next few years…
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-17-2024, 07:57 AM   #2
Re: GM DCT tranny maintenance
I agree, makes you wonder. I myself can not do the every other change of a filter when doing any fluid change. I remember that as a youngster with regular engine oil. Made no sense to keep the dirty filter with all the crud in it and add fresh fluid to it. Change filter every time.
Old 12-17-2024, 11:38 AM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
In this case, the filter gets changed twice before the fluid! WTH?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-17-2024, 06:03 PM   #4
Wow I misread that, still make little sense to me.
Old 12-17-2024, 06:35 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'd say that the filter can be changed without draining the fluid.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-17-2024, 06:38 PM   #6
Accelo
Accelo's Avatar
$38 a quart for AC Delco fluid. Some places charge up to $43.
The fluid needed to fill the transmission is (11.62 quarts)
$456 dollars for the fluid @ $38.
DUAL CLUTCH TRANSMISSION FLUID
Transmission fluid and external filter should be changed after every 24 hours of track usage. If prompted by the transmission fluid life monitor that remaining fluid life is low, the fluid and filter should be changed as soon as possible.Add an additional 2 qt (2 L) of DCT transmission fluid prior to track usage. It is not required to remove the additional 2 qt (2 L) of DCT fluid.Any transmission level set or change should be performed at your dealer. The transmission fluid used in the dual clutch transmission is a specific transmission fluid. Use of unapproved fluid may cause damage to the transmission. See your dealer for the proper transmission fluid.
Accelo is offline   Reply With Quote
Old 12-17-2024, 08:03 PM   #7
Tom
driving is in my blood
Tom's Avatar
Its an auto trans in a vette. So I am negative 1 bizillion on my chances of owning one.
Old 12-18-2024, 01:50 PM   #8
weq92f
weq92f's Avatar
Not necessarily. These cars don't get driven much as the owners typically do not daily drive them. It's more likely the fluid will age out (3 years) before the miles are reached to require a filter or fluid change and so, the fluid changes will need to occur between filter changes. Either that, or the filter gets unnecessarily changed at fluid change time just for convenience (to avoid multiple service visits).
Chevrolet must know these trannys are failing prematurely and it's costing them in the warranty space to repair/replace them. This service bulletin about the importance of keeping up with transmission maintenance along with the warning that not doing so will result in no warranty coverage, is indicative of the kind of long game they're willing to play here. Either that OR this is all just an elaborate money grab and scare tactics to drive it home.
Imagine a 20 something dude who purchases one of these cars in the 60-70k range off the used market while it's still under warranty. If he is unaware of this stuff, he could end up with a very expensive repair bill on that "supercar" purchase of his.
Records of maintenance or other proof the work was done on schedule is going to become very important indeed.
-Kevin
Old 12-18-2024, 01:55 PM   #9
weq92f
weq92f's Avatar
At least it's not the slush box type of auto tranny eh? I mean it's got two real manual style clutches and actual gears that make up the ratios. I don't believe there is a torque converter or clutch packs like in the traditional auto tranny.
While I've not driven GMs version, I have driven other makes of DualClutchTransmissions and SequentialManualGearboxs and will say they are definitely NOT akin to a th400 or 4speed auto but rather more like a real manual transmission.
Agree though that GM should be offering the traditional stick shift in this car!
-Kevin
Old 12-19-2024, 12:02 PM   #10
Dead Parrot
And I thought I was getting ripped off by the $9/quart for Walmart brand Mercon LV fluid that my 09 Escape takes.
Dead Parrot is offline   Reply With Quote
Old 12-19-2024, 01:41 PM   #11
Tom
Tom's Avatar
-Kevin
The internals matter not, if I can't control a clutch pedal then its an auto. Some shift faster then others, some have more gears, but they all do the same thing. And I'm pretty sure I've driven all of them even the exotics.
