Old 12-16-2024, 12:30 AM   #1
berghandler
1970 C10 broken 4x4 shifter
I have a chance to purchase a well used non running C20 4x4 truck that has a broken 4x4 shifter. Could not test dry shifting because of broken 4x4 shifter so can’t tell if transfer case shifting is operational or not. Standard 4 speed shifter did shift ok. Wondering if these np205 transfer cases have a history of becoming tight or what might cause shifter to become broken at connection at transfer case?
berghandler is offline   Reply With Quote
Old 12-16-2024, 08:31 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1970 C10 broken 4x4 shifter
They are as tough as any transfer case is, but anyone who is careless can still destroy them. There is a link on the shifter that can break and fall off. A visual inspection is required. Unless it was run out of oil, or was driven on dry hard surfaced roads for extended periods in 4wd, I would be shocked if the case is destroyed internally.
Old 12-16-2024, 12:20 PM   #3
1970cstblazer
http://www.gmpartswiki.com/getbigpage?pageid=220661
Old 12-16-2024, 08:55 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
What exactly defines broken handle? The shifter is basically a bent steel rod. I can’t see how the shifter would break. Are you sure it’s not an issue with the pivot bolt? Did the casting the bolt threads into break? The 205’s are well sought after for being damn near bomb proof, even at 50+ years old they are still the king in my book.
Tyler
57taskforce is offline   Reply With Quote
Old 12-17-2024, 08:58 AM   #5
berghandler
As mentioned it was broken at the connection to transfer case. Not sure if it’s just the connecting bolt or if threads are also damaged in the case? But in either case would this have been caused by something wrong inside the case is what I’m wondering?
Old 12-17-2024, 09:03 AM   #6
1970cstblazer
Due to different tire sizes front to rear, the drivetrain could have been bound up, and someone forced the shifter and damaged it.
Old 12-17-2024, 12:06 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Best transfer case ever made. Bomb proof, but not idiot proof. I've seen some neglected ones grenade in my time.
To the OP, here is a link to a couple pics that show how the shifter bolts to the top of the NP205. It's one bolt. So if the casting is broken or stripped, it could be the problem.
https://67-72chevytrucks.com/vboard/...22&postcount=3
Or simply the bolt could be missing.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-17-2024, 06:30 PM   #8
jaros44sr
jaros44sr's Avatar
I have a taken apart 205 if you need parts
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-18-2024, 06:18 PM   #9
teamroper!
teamroper!'s Avatar
The little rod from the shift lever to the rails could be broken, don't ask me how I know this can happen lol.
teamroper! is offline   Reply With Quote
Old 12-18-2024, 07:48 PM   #10
Classic Bowties
Always on the hunt...
Wink Re: 1970 C10 broken 4x4 shifter
berghandler, here are a couple of our old archived/saved folder pics on the subject area showing the NP205 t/c shift lever, shift rail and shift link rod parts. If you end up needing the NP205 t/c shift link rod, we have an OE used one available for purchase in the below linked parts board f/s thread. Have a look and let us know, Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=819620
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
