Old 12-19-2024, 04:21 PM   #1
chris989
mysterious death wobble
Hello all,
1989 v2500, 2 inch lift, 37 falkens
A few months ago i experienced my first ever wobble in this truck. Other than a tire rotation and new steering box nothing has changed. It wasn't horrific but definitely a shock since for more than a decade and many many miles it has never done it.
I've been under the truck all morning and nothing looks a miss.. all tight, no movement in and joint, bushing or bearing. (that i can detect)
If you ever had this and figured out the culprit, please share.
Thank you,
Chris
chris989 is offline   Reply With Quote
Old 12-19-2024, 11:00 PM   #2
GM72K10
Next!
GM72K10's Avatar
Re: mysterious death wobble
My death wobble was caused by a partially restricted front brake hose. Put on new front brake hoses and problem went away! Took quite a while to figure that out.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old Yesterday, 01:37 AM   #3
dagnabbitt
dagnabbitt's Avatar
It's scary. On my truck it was the tires, severe cupping. Always happened when tires were cold at 45 mph. With a lift and 37s I would take a look.
Its intermittent because the tires are essentially out of round, and the death wobble only occurs when they all hit the same flat spot at the same time.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old Yesterday, 09:44 AM   #4
raggedjim
raggedjim's Avatar
I've had this on Chevrolet trucks before. On mine it felt more like a hard shuddering.
Had this on my Jeep, new tires cured it.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old Yesterday, 11:22 AM   #5
Willie Makeit
Willie Makeit's Avatar
Worn ball joints have been known to cause this as well.
Willie Makeit is offline   Reply With Quote
Old Yesterday, 12:25 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
do you have the proper or a new steering damper on it ( the shock crossways on the front end) i had a truck that that piece was shot and caused a wobble after the sloppy steering box was replaced
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old Yesterday, 12:28 PM   #7
Stepside Jim
Mine was ball joints...
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old Yesterday, 05:10 PM   #8
Dead Parrot
Happened after tire rotation? Suspect bad or out of balance front tires. Especially if it was a front to back swap.
On my 84 K30, replacing the bushings between the axle and steering fixed it.
Dead Parrot is offline   Reply With Quote
Old Yesterday, 08:31 PM   #9
57taskforce
All about them K’s
57taskforce's Avatar
I assume you are talking about the king pin bushing on the Dana 60? The 10 bolt in his 3/4 ton won’t have those. I’d look into the tires more as well. I’ve even had a late model 3/4 ton IFS GMC that got death wobble because the tires were shot. That’s not supposed to be able to happen on IFS stuff. If it came from out of the blue I’d start with the things most recently changed first. When you add the bigger tires any issues with them just get amplified compared to stock size tires. Toe will cause it too if not set right, with 37’s I’d be shooting for closer to 1/4 toe in if it was me.
Tyler
57taskforce is offline   Reply With Quote
Old Yesterday, 09:20 PM   #10
cadillac_al
2" isn't much lift to cause a problem. I have had my K20 for 30 years and had the 2" lift and 35's for 20 years. The only time I had death wobble is when I had too much mud in the wheels. With clean wheels it will roll nice and smooth at 70-80 mph. On my Jeep Grand Cherokee the only time I had death wobble was with old flat spot tires. I always blame the tires first
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
