Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 12-19-2024, 08:32 PM   #1
65truckowner
65truckowner's Avatar
10 inch wide rallies
My son has come across a set of rim that look like the five lug chevy rallies from the early 80s BUT they are 10 inches wide. Anyone heard of these type of rim?
65truckowner is offline   Reply With Quote
Old 12-19-2024, 10:53 PM   #2
Boog
laying low
Boog's Avatar
Re: 10 inch wide rallies
Sure. They were not from GM. 8" was the widest GM ever made. You could buy 10" from aftermarket like Wheel Vintiques and at one time Summit. Since then I believe Coker Tire in Tenn own the GM truck rally rights.
Back in the 80s I made my pair of 10s by cutting and welding. I've never wanted to do that again.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old Yesterday, 09:06 AM   #3
Keith Seymore
Keith Seymore's Avatar
Agree.
This is what I do (with Corvette style rallys).
I've got two complete and two in process.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old Yesterday, 02:44 PM   #4
weq92f
weq92f's Avatar
Originally Posted by Keith Seymore View Post
Agree.
K
Seems to me like the resulting wheel, after cutting and welding, would not be precisely "true" such that if you rolled it along flat surface, it would likely wobble to some degree (the welded pieces aren't exactly square). That is unless some type of jig is used to ensure the two halves are mated together square and plumb.
Am I just all wrong here? Would a very very slight wobble even manifest itself in some way? A huge one would, but if it's just a 32nd or less?
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old Yesterday, 05:03 PM   #5
Keith Seymore
-Kevin
Yes - there is a lot of jigging and fixturing going on.
I keep the relationship between the bolt circle and the front of the rim intact and then reference off that. The rear portion consists of a sacrificial wheel with the added material.
I can keep them within .010" variation both laterally and radially.
K
1979-1986
1986 - 2019
Old Yesterday, 05:13 PM   #6
weq92f
weq92f's Avatar
I keep the relationship between the bolt circle and the front of the rim intact and then reference off that. The rear portion consists of a sacrificial wheel with the added material in that.
K
...and looks like you can put quite a lot of stress on your welds without fear!
.010 is pretty impressive.
Thanks,
-Kevin
