Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-31-2024, 05:47 PM   #1
RonWT
Active Member
RonWT's Avatar
Condensers?
Can anyone tell me why there are 3 condensers under the hood of my 69 C10? One attached to the coil, one attached to the points, one attached to the voltage regulator.
Thank you.
RonWT
RonWT is offline   Reply With Quote
Old 12-31-2024, 07:50 PM   #2
dmb
Active Member
dmb's Avatar
Re: Condensers?
radio suppression maybe. Also you can run a condenser on the coil and do away with the one at the points I believe
Old dogs and children and watermelon wine
dmb is offline   Reply With Quote
Old 01-01-2025, 02:44 AM   #3
Dead Parrot
Re: Condensers?
I know from experience that a bad condenser on the points can cause bad running. Helped a friend chase a poor performance issue. He had installed a new point/condenser set(so it couldn't be that...). After most of a day of wailing and teeth gnashing, he pulled the used condenser off the old points and replaced the new one, MAGIC! It ran great!.
The one on the coil is probably noise suppression.
The one on the voltage regulator is probably to reduce wear on the relay contacts.
There is often one inside the alt for noise suppression.
Dead Parrot is offline   Reply With Quote
Old Today, 01:58 PM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Condensers?
To prevent radio noise interference.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
