Old 01-01-2025, 11:55 AM   #1
Sebambam
53' GMC 3 on the tree help
Hi Team i am in the process to fix a 53 Longbed GMC truck with a GMC 228 engine.
We opted for a CLIFFORD intake with headers and a Weber 38 carb for a bit more performance.
The truck spend his last years in PAINTJAIL , the painter disassembled the Truck and now i piece the Puzzle together .
the Engine is running, It has New wiring, got converted to Throttle cable and i am in the process of putting the Clifford kit on it.
As expected i run into issues with the Shifter
1st issue the shifter was disconnected so i am trying to figure out the linkages.
i would like to find a diagram and how to correctly position the Shift lever on the steering wheel.
I can also see that the linkages on the Steering shaft will hit the Clifford intake.
How have you guys solved this?
We already considered a Floor Shifter?< if so what floor shifter do you recommend?
Further the CLUTCH PEDALK LINKAGE to the trans was disconnected .
DO you have any pics of the correct Linkage that i might have in all the Parts bins that came with the truck?
if not whats a good replacement part.
please see some pics attached
i am located in DFW TX
Sebambam is offline   Reply With Quote
Old 01-02-2025, 01:58 AM   #2
franken
Re: 53' GMC 3 on the tree help
A 53 foot long GMC?
franken is offline   Reply With Quote
Old 01-02-2025, 04:11 AM   #3
RustyPile
RustyPile's Avatar
Have you looked into the feasibility of leaning the engine over toward the passenger side just enough to gain clearance??
RustyPile is offline   Reply With Quote
Old 01-02-2025, 02:07 PM   #4
Sebambam
Originally Posted by franken View Post
A 53 foot long GMC?
no 53 Ft Lbs long !
Old 01-02-2025, 05:26 PM   #5
geezer#99
geezer#99's Avatar
Isn’t a 53footer considered a short box!
The best floor shifter is a hurst master shift.
Like this one.
https://www.summitracing.com/parts/h...yABEgIM7fD_BwE
Old Yesterday, 12:42 AM   #6
Sebambam
Like this one.
Thanks , that will eliminate the linkage issue for sure.
Will the trans existing linkage bolt right up?
Old Yesterday, 10:19 AM   #7
geezer#99
geezer#99's Avatar
Nope.
You also need a kit with the brackets and rods to set up a floor shift.
Like this.
https://www.holley.com/products/driv...shift_3-speed/
Old Yesterday, 11:35 AM   #8
Sebambam
Nope.
Like this.
Jup i found out by researching yesterday , thanks for the help.
I hope it clears teh bench seat accordingly.
i will look up which trans we have exactly to get the right linkage and shifter...
PS the clutch pedal linkage is missing too the fork doesnt get engaged , i have to source that one too...
Old Yesterday, 11:49 AM   #9
geezer#99
geezer#99's Avatar
Shifter handle can be tight to the seat but there’s a cure for that with a shifter like this.
https://www.shifterdoc.com/productca...-Seat-p277.htm
