Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 01-04-2025, 01:10 PM   #1
Ziegelsteinfaust
Carburetor cleaners
Yesterday I pulled apart a few Edelbrocks to clean for a friend, and rebuild the best one. They were greasey so I didn't want to mess up my carb dip cleaning that stuff up.
So I soaked 2 of them in purple power cleaner. The non acidic version, and they came out cleaner then the one I soaked in the carb dip. They just required a quick blow out with compressed air, and a spray with carb clean to displace the water.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-04-2025, 02:00 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Carburetor cleaners
How do you identify the non-acidic version when buying? Do you dilute it or use it full strength? How long did you soak?
dmjlambert is offline   Reply With Quote
Old 01-04-2025, 02:02 PM   #3
farmall
farmall's Avatar
As far as i know, there is no acidic version. It is high pH. Caustic.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 01-04-2025, 05:52 PM   #4
Ziegelsteinfaust
It will have a variation of this symbol
https://images.app.goo.gl/eeFUjZ6rG8pMsjUM8
Where i live. Home Depots Zep purple cleaner is acidic. Where the actual brand purple power is not.
I did a 4-1 ratio or water/cleaner.
My first run was 12 hours roughly. Which seemed to do everything I needed. I scrubbed it down with a short bristle paint brush.
The gaskets that were stuck came up easy will barely any residue left.
The remaining gas residue came off with a quick scrub, and spray of carb clean. All carbon was practically gone after a quick scrub.
If you use the acidic cleaner it will mess up the finish.
