01-15-2004, 11:25 AM | #1 |
Tach Question?
I GOT THE TACH HOOKED UP ON MY TRUCK AND IT REALLY SUPRISED ME TO SEE HOW MANY RPM'S MY THESE TRUCKS TURN.
IT HAS A 307 ENG AND A THREE SPEED TRANNY, AND ON THE HIWAY IT WAS TURNING BETWEEN 3500-4000. DOES THIS SOUND RIGHT OR COULD THE TACHOMETER BE OFF? THANKS |
01-15-2004, 11:33 AM | #2 |
What rearend gears do you have?
01-15-2004, 12:06 PM | #3 |
Try spinnin 4 rear tars
well for a comparison, I have 3.08's, and I turn 3000 running ~80mph
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
01-15-2004, 01:01 PM | #4 |
GEAR
I'M NOT SURE WHAT GEAR. IT IS A SHORT STEP SIDE PLANE JANE TRUCK
WITH NO A/C OR ANYTHING. WE PUT POWER STEERING ON IT. |
01-15-2004, 01:09 PM | #5 |
The truck probably has a 3:73 in it, but depending on the speed the tach could be off. The tachs are adjustable and with a reference tach, it is pretty easy to do.
Jim |
01-15-2004, 01:55 PM | #6 |
TACH IS ADJUSTABLE?
HOW DO YOU ADJUST IT? I'M GONNA PUT A TIMING LIGHT ON IT AND SEE IF IT IS OFF, BUT IF IT IS HOW DO YOU ADJUST IT?
THANKS |
01-15-2004, 02:01 PM | #7 |
Beer Power!!!!!!!!!!
That sounds right to me. I have the same set up in my all original truck and it screams at 70.
Rather be fishin' |
01-15-2004, 03:06 PM | #8 |
If you look on the back of the tach there is a small piece of tape covering the adjustment screw. Just hook up a second tach, (known to be accurate and adjust your tach to match).
Jim |
01-15-2004, 03:15 PM | #9 |
THANKS!
I didn't know that. That is pretty cool. Thank you for the help!
