Old 01-05-2025, 10:03 PM   #1
Bob B.
Reproduction Auto Trans Crossmember
Anyone have any experience with these? Hard to install?
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 01-05-2025, 11:10 PM   #2
Willshook
Re: Reproduction Auto Trans Crossmember
I installed this one on my ‘72; fit perfectly.
https://classicperform.com/cp9427
I had to sawzall the old one out; even after removing all the bolts I couldn’t slide it out.
Willshook is offline   Reply With Quote
Old 01-06-2025, 12:41 AM   #3
Bob B.
I have been looking at that style of crossmember. The OEM type is also available as well:
https://www.classicindustries.com/pr...s/t677205.html
Old 01-06-2025, 07:33 AM   #4
This is the one I'm using in my 70. It seems to fit well, but I don't have the tranny in the truck yet.
https://www.ebay.com/itm/193432100723
Old 01-06-2025, 12:34 PM   #5
PbFut
Pretty good Price at summit.
https://www.summitracing.com/parts/sum-770580
I found it allows for a way easier job dropping the tranny pan for service. With the factory unit, I had to unbolt and slide the member back to have enough room. This aftermarket part can remain in place while performing service. It does not have and attachment to the top of the frame rail like factory. So if you are concerned about a rail twisting, the added support is no longer there. I've found no issue but I've not worked the truck that hard since install a couple years back.
PbFut is offline   Reply With Quote
Old 01-06-2025, 12:58 PM   #6
Willshook
For sure easier to drop the pan - and makes a LOT of room for an aftermarket exhaust. The stock crossmember didn't leave room for my Magnaflow exhaust.
Old 01-06-2025, 02:19 PM   #7
guyryan100
guyryan100's Avatar
I have always wondered if the crossmember plays any real structural role other than holding up the transmission, that might be reduced with the aftermarket options that only bolt to the bottom of the frame.
To get my 700r4 transmission pan off, I unbolt the transmission mount, jack up the tail shaft and get a wrench into the pan bolts, use a pump to remove the fluid via the filler tube, and wiggle the empty pan out from the crossmember - the aftermarket crossmember would make that so much easier!
guyryan100 is offline   Reply With Quote
Old 01-07-2025, 01:34 PM   #8
Bob B.
It might, but it's pretty close to the large crossmember that the trailing arms attach to.
Old 01-07-2025, 06:14 PM   #9
Cal10
I have one of these sitting in my garage. It’s yours free if you want it, it fit my truck well but didn’t clear the shift linkage on my Muncie. (It’s made for automatics, I just hoped I could make it work) https://www.crossmembers.com/product...ember-rcc-10-2
Cal10 is offline   Reply With Quote
Old 01-08-2025, 12:59 PM   #10
Bob B.
Thanks, I appreciate it. I have an original I am thinking about using.
