Old 01-06-2025, 09:24 PM   #1
prateroad
NP205 output shaft swap
Is this a straight swap from sliding yoke to fixed yoke with no problem. Changing out one to the other, not the whole transfer case?
prateroad is offline   Reply With Quote
Old 01-07-2025, 12:58 AM   #2
kwmech
Re: NP205 output shaft swap
Yup, just pay attention to the pocket bearing needles on the inside of the output gear when you pull it out. They will still get jumbled up, but pay attention to them falling down inside the case. Tip the case back as far as you can without it falling off the bench. That case appears to be a round 6 bolt case adapter mounting as it is worth some bucks
