Old 01-07-2025, 02:21 PM   #1
TyFullCircleFab
Lift kit for 2wd
Full Circle Fabrications “BOLT” on long travel suspension kit specifically designed for 67-72 Chevy trucks. Finally a suspension kit that doesn’t put you on the ground! This was designed for functionality but looks great too. It’s 3” wider per side and has 12.5”+ of useable wheel travel using 8” travel coil overs, all while keeping your stock steering!
Kit includes:
-upper and lower control arms (powder coated) -mounting plates
-Grade 8 mounting hardware
-spindles
-heims and uniballs
-steering ujoints and dd steering shaft
-extended steering arms
Kits priced at $3800
More information at fullcirclefabrications.com
TyFullCircleFab is offline   Reply With Quote
c10, lift, lift kit, long travel, off road
