87 4x4 TBI issues
I'm working on a 87 V10 with a TBI 350. I'm having odd issues with keeping it running. It would not run with MAP connected and ran poorly with it disconnected. Replaced map sensor and fired up and ran much better but after about 10 minutes sputtered and died out. After dieing it would start and immediately die every time. Let it sit for awhile and it will repeat this situation. To add to the confusion my will not connect to the truck unless it is running. If it is running I can pull codes some times. Other times as the scanner is trying to to connect the truck will sputter and almost die and as soon as it stops trying to to scan the motor comes back to idle correctly.
This truck has new fuel pumps and shows 10 psi after the tank selector switch.the TBI unit has been cleaned and resealed. The pressure regulator was replaced when cleaning. We have replaced the map sensor. Checked connections at the end and no corrosion. No corrosion visible from the chip window in the ecm. Whe I can pull codes I get these numbers: 13 14 25 34 35 41 43 Anyone have any ideas on a direction? I've been out of the TBI game for AWHILE and feel like I'm floundering. I'm trying not to parts cannon and fix it right. |
| Bookmarks |
| Tags |
| k10. tbi |
