Old 01-09-2025, 07:28 PM   #1
1960chevypanel
Leaky steering box
The PS gear box on my truck is leaking pretty bad at the rear seal (by the rag joint). Can that be fixed on the truck or do I need to pull the box?
1960chevypanel is offline   Reply With Quote
Old 01-09-2025, 10:17 PM   #2
blakeduren
Re: Leaky steering box
It can be fixed on the truck. Pull rag joint/steering shaft loose. Snap ring holds in the seal in the steering box. I had to drive a small sheet metal screw into the seal to get it pulled off if I remember correctly.
The bottom sector shaft seal is easier that the input seal if you just want to replace both at the same time.
blakeduren is offline   Reply With Quote
Old 01-10-2025, 02:48 PM   #3
Shark_13
I may have to do mine as well, looks pretty damp around the steering gearbox.
I have actually had good luck with 2 other vehicles using the Lucas steering stop leak. I may just try it again.
Old 01-10-2025, 05:55 PM   #4
projo198
It's really not too hard to pull and completely rebuild, and the kits are cheap/found locally. Takes about 30 minutes.
I just did mine when I switched arms for a crossover bar.
projo198 is offline   Reply With Quote
Old 01-11-2025, 03:19 PM   #5
1960chevypanel
That's great info, thanks! Where did you source the seal?
Old 01-11-2025, 03:22 PM   #6
1960chevypanel
The box actually works perfectly. Doesn't have any noise or slop, just sprung a leak.. Seems like pretty much every system on this truck leaks!
Old 01-12-2025, 11:31 PM   #7
blakeduren
Seems like the seals are still available easily, it has been several years since I did this last.
Search for
"Power Steering Gear Seal Kit"
at your local parts house.
Old 01-14-2025, 05:36 PM   #8
projo198
I gotcha! I just figured with the ease of the job I may as well replace all the seals rather than the one. That bottom one is most prone to leakage though. Good luck with it!
