Old 01-13-2025, 07:13 PM   #1
BanjoDude
Tightening up a 3 on the Tree
Hi guys,
I'm trying to tighten up the shift linkage on my '69 C-20 with 3 on the tree. I've replaced the shift linkage bushings and adjusted the linkage, and that made a huge difference. The remainder of the slop is coming from the collar on the column that the shifter connects to (outlined in green in the attached pic). The collar itself wobbles up and down as well as axially a fair bit. I've looked high and low for diagrams on how to rebuild that section and for parts with no luck. Has anyone fixed this successfully? If so, where did you get the parts and the diagram to know what to order and replace?
I can't believe this is so hard to track down given the number of these that were sold. I'm finding a ton of stuff on the automatics and the floor shifters - but not one diagram or parts source for the 3 on the tree. Perhaps I'm missing something right in front of my nose? Any help would be appreciated.
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again.
"For just a little more, you can do it yourself!"
BanjoDude is offline   Reply With Quote
Old 01-13-2025, 08:41 PM   #2
notsolo
notsolo's Avatar
Re: Tightening up a 3 on the Tree
This is from the 72 book, might be worn, but someone added cruise control might be missing a piece. Good luck....Also a post "3 OTT missing pieces" shows #39 and 40
notsolo is offline   Reply With Quote
Old 01-13-2025, 08:56 PM   #3
notsolo
notsolo's Avatar
#40 nylon thrust washer and #39 rubber bushing....I think 69 would be the same.
Old 01-13-2025, 11:11 PM   #4
BanjoDude
This is fantastic! Thank you kindly. Any idea where I could cross-reference those figures to part numbers?
Old 01-14-2025, 07:50 AM   #5
notsolo
notsolo's Avatar
Maybe this, searched specific part name thrust washer 1969 chevy truck.
Old 01-14-2025, 10:49 PM   #6
BanjoDude
Unfortunately, that's for an automatic.
Old 01-15-2025, 09:21 AM   #7
68panelman
68panelman's Avatar
There is an NOS shift housing on ebay for $76 from horsepower? He's a vendor here too, unsure spelling. Just in case when you open this up, it's not all gouged and damaged beyond repair, he may have the bushings you are seeking too
68panelman is offline   Reply With Quote
Old 01-15-2025, 09:53 AM   #8
BanjoDude
Any chance you could post a link? I searched NOS Chevy shift column on eBay and didn't find one for a 67-72 truck. I'd absolutely buy that if it has all the internals.
Old 01-15-2025, 10:00 AM   #9
68panelman
68panelman's Avatar
It's only the outer aluminum housing, no internals
Old 01-15-2025, 10:19 AM   #10
68panelman
68panelman's Avatar
I tried posting a link but errors kept coming up
Research horsepower products on eBay page 2
Old 01-15-2025, 10:41 AM   #11
BanjoDude
Found it! Thank you!
Old 01-15-2025, 11:13 AM   #12
68panelman
68panelman's Avatar
Glad to be of help. Good luck with the repair
Old 01-15-2025, 06:07 PM   #13
Classic Bowties
Always on the hunt...
BanjoDude, the #40/thrust washer shown in above post #3 by notsolo is for a 4 speed manual (non-shift lever) column and would be an incorrect non-fitting part for your 3 speed manual steering column. Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 01-16-2025, 10:06 AM   #14
Classic Bowties
Hi guys,
BanjoDude, after nearly twenty years in here and while sitting here typing, am trying to figure out and understand why so many are quick to post outside links and options for column repair parts (sometimes incorrect) when most times we have the correct stuff available in either GM NOS or quality OE used right here onsite on the 67-72 parts board. I find myself posting the below link to our long running steering column parts board f/s thread just about weekly here in the main 67-72 forum area, we have a large group of original steering columns for parts pulled and stored along with several shelved bins of OE used, GM NOS and also new repro replacement column parts on hand ready to ship out. We currently have the following parts available in GM NOS for your 69 3 speed manual steering column overhaul (see below column parts diagram): #2/shift lever control housing lower plastic wear bushing, #39/shift lever control housing upper rubber washer bushing, #40/shift lever control housing upper plastic thrust washer bushing and #41/shift lever control housing. We have added the details and pricing in our below linked steering column parts f/s thread in post #60/#61 and offered you first option on these items, please confirm in the f/s thread if interested. Thanks, Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=838093
Old 01-16-2025, 10:09 AM   #15
Classic Bowties
3 speed manual steering column parts diagram and NOS 67-70 3 speed manual shift lever control housing pics...
Old 01-17-2025, 01:42 PM   #16
Classic Bowties
Hey Wes, per your added request here's round two on the parts that we have on hand/available for your 3 speed manual column overhaul and yes, we already have the #34/GM NOS upper shaft bearing available as list item #1 in the top post of that above linked steering column parts f/s thread. Here are some pics of the #3/GM NOS shift lever control lower metal bushing seat, #7/GM NOS 3 speed manual specific back up lamp control switch , #33/GM NOS turn signal switch and wire harness assembly and the New Repro turn signal switch cam, this cam is not shown individually on below parts diagram. Check everything out and let us know, Mel
Old 01-17-2025, 01:45 PM   #17
Classic Bowties
3 speed manual steering column parts diagram, GM NOS Delco Remy turn signal switch assy. and new repro turn signal cam pics...
Old 01-23-2025, 09:44 PM   #18
BanjoDude
I'm back with a question. Can anyone tell me the proper way to orient the "notch", or thinner part, on item 39 (the black rubber bushing)? I can't tell for sure why that's there. It doesn't appear to match up with an adjacent part that is obvious to me.
