Old 01-14-2025, 05:24 PM   #1
PbFut
Column shifter question
I have reinstalled the steering column. Engine and trans still out. I can't recall the position relationship of the detents and the indicator in the cab. With the indicator showing in the P position is the detent at the bottom of the column on the first position or all the way past the edge If all the way past the first step, then my indicator is way off. I suspect the linkage when attached to tranny would stop the travel so the column decent does not travel past the edge? Photo is if the detent past the edge. It was difficult to get an angle to show what i am referring to. Can someone confirm this does not happen with linkage to trannt connected?
PbFut is offline   Reply With Quote
