Old 01-16-2025, 05:09 PM   #1
MikeB
MikeB's Avatar
Gasket sealant
It's been a while since I did any work requiring gasket sealant. Getting ready to replace a fuel pump and water pump on a Gen I 350.
What do you guys recommend for oil- and coolant-resistant sealants these days? Hi-Temp RTV or something more traditional?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-16-2025, 06:30 PM   #2
truckster
truckster's Avatar
Re: Gasket sealant
For those applications I like to coat gaskets with Permatex Aviation Form-a-gasket.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-16-2025, 06:49 PM   #3
MikeB
MikeB's Avatar
Re: Gasket sealant
Now that's old skool!
Mike
Old 01-17-2025, 01:44 AM   #4
Ziegelsteinfaust
Re: Gasket sealant
I myself just use black rtv.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-17-2025, 07:19 AM   #5
WorldsCrappiestTruck
Active Member
Re: Gasket sealant
I use a thin coat of loctite 518 anaerobic sealer on each mating surface of basically anything I assemble regardless of where. Diff covers, oil pans, water pump gaskets. Put a couple dabs on the surface, smooth with your finger to make an even thin film and send it away.
On gaskets that have a “ridge” molded into the rubber gasket like LS intake, throttle body, etc….i just leave them alone and install dry.
WorldsCrappiestTruck is offline   Reply With Quote
Old 01-17-2025, 11:55 AM   #6
Willshook
Re: Gasket sealant
RTV Black for anything coolant.
Aviation form-a-gasket for anything fuel/oil.
Willshook is offline   Reply With Quote
Old 01-17-2025, 05:59 PM   #7
Orange Crate
Orange Crate's Avatar
Re: Gasket sealant
Permatex Gear Oil Gasket Maker 81182. This stuff is really good.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 01-17-2025, 09:28 PM   #8
truckster
truckster's Avatar
Re: Gasket sealant
True, but it still works.
