01-17-2025, 04:27 PM | #1 |
72 inside door panels on 70 doors
From reading old posts, I understand the panels will fit but need to change window regulators and such because the 72 panels are wider than the 70 panels. I found spline extensions on ebay that extends the shafts out 5/8". How much do I need to extend the shafts? Would the 5/8" longer work? I already have the 72 panels, didnt realize they were wider when I got them several years ago. Thanks!
01-17-2025, 05:36 PM | #2 |
Re: 72 inside door panels on 70 doors
Can't you put the extensions and panels on and just see if they fit? When you put new panels retainers on, soak them in hot water and they won't crack.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
01-17-2025, 08:52 PM | #3 |
Junior Member
Never heard of those extensions. I put 72 door panels on my 71 suburban 25-30 years ago. for front doors i got good used regulator's from a pick-up changed at the same time i installed OEM tinted windows. The third door and non door were a little more difficult to obtain. After searching for a few months I salvaged some posts from 72 regulators , drilled the rivets out of my original regulators installed the longer posts. Three weeks later found 72 suburban doors with regulators. My suggestion is just get 72 regulators. It's the best way. Not to tough to change out the regulators.
01-17-2025, 09:23 PM | #4 |
Pre 72 door panels have captive nuts welded to the door, 72 only have holes for plastic fasteners to go in. That said you can still make 72 panels work by changing regulators and drilling out for plastic fasteners
01-18-2025, 06:36 PM | #5 |
Junior Member
It's been a while but I don't remember having to drill out any captive nuts to install 72 regulators on my 71 suburban.
01-18-2025, 06:39 PM | #6 |
01-18-2025, 11:33 PM | #7 |
You also need the door openers for a 72
01-19-2025, 04:33 AM | #8 |
Junior Member
Yes replaced all 7 units on my suburban somewhere around 1995-96
01-19-2025, 01:30 PM | #9 |
01-19-2025, 02:54 PM | #10 |
Wish I had saw those before. I replaced my original 67 with 72 gm restoration pieces for my doors which were junk and handles rattled.
01-20-2025, 09:12 AM | #11 |
Well, those are neat..
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
01-23-2025, 03:17 AM | #12 | |
Drilling out is the hard way. Unless they're really crusted with rust. IDK about that. I live in AZ.
