Old 01-21-2025, 01:49 PM   #1
Casper42
Casper42's Avatar
lowering and alignment question
if and when is alignment needed?
I installed CPP drop coils - 2" front, 3" rear with lowering shocks...no new spindles, C-notch, or panhard. A test drive reveals no issues, other than an occasional pop and creak when hitting a dip or at times making a turn - likely settling new hardware.
I've read that I should drive for a week or two before having the alignment inspected/adjusted, while one pro shop recommended I have it done right away. Another said it's not needed at all unless I note a issue, because the tie rods were not disconnected/reinstalled.
Your thoughts are appreciated. Happy New Year!
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 01-21-2025, 02:51 PM   #2
Accelo
Accelo's Avatar
Re: lowering and alignment question
You can do major damage to your tires in a week. Get it aligned as is.
Running out of travel on the upper A-arm where it bolts to the frame is possible.
Hopefully, you will not have this issue.
If you do, run out of travel, there are many solutions.
Running tubular A-arms
Relocation of the ball joint
Modifying the length of the A-arm by welding our purchasing modified one.
Likely another solution I haven't thought of also.
Accelo is offline   Reply With Quote
Old 01-21-2025, 08:38 PM   #3
weq92f
weq92f's Avatar
Do it yourself. I helped(watched) a buddy align his 2002ish ram 1/2 ton using hand tools on the shop floor. A simple device is used to extend the plane of both front wheels horizontally such that tape measures can be used to accurately spec various geometry metrics. He didn't do caster/camber but managed the toe adjustment in less than 30 minutes. caster/camber can also be measured/set using a tool such as the one below. Simple toe adjustment can also be accomplished with good old string and anchors like in the link.
tool example
https://www.ebay.com/itm/28559258377...32523ab4b09873
Using string:
https://blog.1aauto.com/diy-wheel-al...e-by-yourself/
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-21-2025, 08:42 PM   #4
72c20customcamper
72c20customcamper's Avatar
Do it as soon as possible . By lowering the truck with springs you changed the geometry of the front wheels . By not changing or disconnecting the tie rods you may not have changed the toe but the drop definitely affects the camber and caster
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-22-2025, 12:16 PM   #5
Joyridin
Have it done right away, but avoid the shop that said you didn't need to have it done. They have no clue what they are talking about.
You changed the caster, camber, and probably the toe even if you did not unhook the tie rods. It may not be enough to notice, but it more than likely changed and not for the good.
Joyridin is offline   Reply With Quote
Old 01-22-2025, 01:01 PM   #6
HO455
Post Whore
HO455's Avatar
By all means as stated above get it aligned. Personally I would avoid the shop that said it didn't need to be done.
RIP Bob Parks.
Old 01-22-2025, 01:13 PM   #7
SCOTI
SCOTI's Avatar
I fully agree w/72c20customcamper, Joyridin, & HO455.
Get it in for alignment sooner than later if you plan to continue using the current front tires.
And, as mentioned.... avoid the shop that said there's no need because the TRE's weren't disconnected. While there is some truth to that in certain situations, yours is not one of them.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-22-2025, 04:13 PM   #8
Rust_never_sleeps
Rust_never_sleeps's Avatar
Mine is stock height, I matched the lengths of the tie rods, never touched the shims, and it was way off :shrug:
They did stick me pretty good for a "classic vehicle" alignment, so one of the alignment tools would pay for itself quickly if you can get both toe-in and camber set at home
I was pretty good with trigonometry 45 years ago, but haven't used it much recently ;-)
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 01-22-2025, 05:52 PM   #9
SCOTI
SCOTI's Avatar
The issue w/that is they can all impact each other. Get Toe & Camber adjusted @ home & then take it to the shop to get Caster set? They start adding or subtracting shims to dial in that Caster & now your 'preset' Toe & Camber will be different.
This is why it's good to have a set-up that allows adjusting things together if you plan to DIY. The numbers can be dialed in for each so that they all work together.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-22-2025, 08:30 PM   #10
Casper42
Casper42's Avatar
thank you everyone for your input ✅
