Old 01-24-2025, 11:14 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Dakota Digital issues
I’ve had a Dakota Digital dash in my 70 for 10+ years. All of a sudden as I’m driving along the Tach, SpeedO, Fuel gauge and temp gauge will go to Zero then back AND it’s not always all the gauges but always the Tach and SpeedO
Volts and Oil Pressure are not affected. I am running an LS just FYI
Has anybody else experienced this???
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old Yesterday, 09:45 AM   #2
Joyridin
Re: Dakota Digital issues
Are you picking up the speedo from the OBD port or is it set-up separately using the VSS in the trans?
Joyridin is offline   Reply With Quote
Old Yesterday, 02:23 PM   #3
1970 CST Short Wide
Senior Moment
OBD port
Pittsburg Ca
94565
Old Yesterday, 09:13 PM   #4
Rufas
Rufas's Avatar
Have you contacted Dakota Digital about this? I've had good results from their support.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old Yesterday, 11:59 PM   #5
1970 CST Short Wide
Senior Moment
Yes. They said to check connections. It’s worked perfectly for 10+ years. I guess a connection could come loose ??? Anyway I’ll pull the unit and check out the connections
Pittsburg Ca
94565
