Old 01-15-2004, 06:45 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Idea for cab corners on interior
Here is a little idea I came up with for mounting speakers in the wasted cab corner space. Welded a couple of pieces of 1" angle iron to the body then fabed 16 gauge panels to attach with bolts. I had to cut a hole in the passenger side door jamb for a vent so I could put the nuts on the bolts. Next I will cut the holes for the speakers and carpet the whole shebang when done. I plan on filling the cavity behind the speakers with insulation bats and also will put Dynamat on all surfaces.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 01-15-2004, 06:53 PM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
PIC 1
Pic 1
Just Passin' Thru
Old 01-15-2004, 06:53 PM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
PIC 2
PIC 2
Just Passin' Thru
Old 01-15-2004, 08:36 PM   #4
72MARIO
72MARIO's Avatar
I just did kinda the same thing. I welded 1/2 inch 90 degree brackets to the same spot you welded the angle iron. I used a fender clip to be the nut. I decided to use plt wood to fill in the opening. Same plan with the Dynamat.
Looks good Dude
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-15-2004, 11:27 PM   #5
Hooter
My other Love
Hooter's Avatar
thats a real good idea, just make sure you dynamat it real good in there, it will cut down on the rattles and give better bass response
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-15-2004, 11:30 PM   #6
Quagmire
A splendid one to behold
Quagmire's Avatar
cool idea! i think i have a bottle of tranny fluid on one side and a handful of shop rags on the other
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 01-15-2004, 11:55 PM   #7
CG
BlahBlahBlah
i think i have a mouse nest on both sides
Old 01-16-2004, 12:47 AM   #8
joerocks
i just keep rust in mine
1992 Jeep Cherokee 4.0 AUTO
1972 C10 350/350
1971 C1500 350/350
1970 C20 396/400
joerocks is offline   Reply With Quote
Old 01-16-2004, 12:47 AM   #9
nosto
Flamin' Bass
nosto's Avatar
Yup, that does work. I've got a pair of old 2-way 5X7s mounted on 1/8" lauan and covered in fabric. Just used a small angle bracket screwed and countersunk in the door jamb. Added a small amp, a 12" sub in the center console and a pair of 1" dome tweeters in front. And a bunch of Cascade (Dynamat clone) for sound dampening. No buzz or rattle even when cranked up.
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 01-16-2004, 08:04 PM   #10
MeannGrumpy
Mouse nests
Must be nice to have mouse nests. lost mine quite a while back, seems they just fell out
1970 Longhorn, factory air & Cruise,Tach vac
1970 C 20 3/4 4x4 350 with turbo 350 auto,
MeannGrumpy is offline   Reply With Quote
